For this one, is it possible to ask for a guidance for where to work on?
I am not sure if I should makes changes only to the Gamification plugin, or the Reaction plugin as well. Since not every site uses the Reactions plugin, is it okay to include settings about reactions in the gamification plugin?
סיכום מבוסס בינה מלאכותית
The discussion revolves around the feature request “Add Scores for Reactions”. Nam asks for guidance on implementing per-reaction score awarding, which requires the “Discourse Reactions - Beyond Likes” plugin. matenauta suggests enabling the option only if the Reactions plugin is found. Falco confirms this approach is acceptable, citing the existing implementation for Discourse Solved. Nam shares a pull request (PR) for the implementation and requests feedback.
Can that option only be enabled if Reactions plugin is found? I think that could do the trick ![]()
Yes, we already do this for Discourse Solved. Since every scorable extends the base Scorable class you can redefine the enabled? method to check if a plugin is installed and enabled.
I worked on this one. Here is the link for the PR:
Please let me know if there are any issues!
