Would you be open to a PR that makes it default for anonymous users (now they never see a signature) and/or set it to “default on” for users?
There are some uses for this plugin (for instance where the signatures are used for contact info) and it would be helpful if the signatures were visible by default on such forums.
          If it’s under a site setting and doesn’t defaults to “on”, yeah I don’t see any problem with that! Thanks for the offer!
