Admin panel has broken i18n translation stubs
For some reason, without any changes, the entire admin panel translations completely broke. I’ve tested switching the language, but that just changes the en to the other language, but doesn’t fix it.
Only the admin panel has broken, the rest is completely fine
Thank you in advance.
Can you try
cd /var/discourse
./launcher rebuild app
Sorry, forgot to mention, already tried multiple times
Any custom plugins? does this happen in safe mode?
Just tested, still broken:
Custom plugins may need uninstalling and rebuilding. Also, are there any errors in chrome dev tools. Maybe it is getting an error asking for admin locales js file.
Ok, this is silly, cloudflare had turned on their “Rocket Loader”, which caused it to load outdated jquery, which errored the template thingy, which cause the problem. Thanks for the help!
