Hi, all amdin strings are gone when I did a rebuild to install a plugin.
I can’t find a way to fix this.
סיכום מבוסס בינה מלאכותית
User amine reported that all admin strings disappeared from their Discourse instance after rebuilding to install a plugin. Initially, codinghorror suggested the plugin was broken and should be removed. amine identified the culprit as the official Discourse Slack plugin but noted that removing it and rebuilding did not resolve the issue. codinghorror expressed confusion since no other third-party plugins were active, leaving only the Docker Manager plugin. zogstrip advised rebuilding the container without any plugins, but amine confirmed this also failed. When asked about the locale, amine confirmed it was set to English and that forcing it in app.yml did not help. zogstrip requested the app.yml file for further inspection, which amine provided. Upon reviewing the configuration, zogstrip identified a JavaScript error related to Cloudflare on the site, suggesting it might be the root cause. amine questioned the connection, but after addressing the Cloudflare issue, amine confirmed the problem was resolved.
Your plugin is broken. Remove it.
Thanks Jeff.
It’s the discourse slack official plugin:
https://github.com/discourse/discourse-slack-official
I did a rebuild after removing the plugin: it did not fix the problem.
Odd, if no plugins are third party then I am not sure what it is.
Yes it’s odd. The only plugin I have is docker manager.
Any idea how can I fix it manually ?
Can you try without the plugin and rebuild your container?
Hi Régis,
I did it. did not fix the problem.
What locale is your Discourse in?
My locale is EN.
I tried also to force it in app.yml (did not fix the problem)
Can you share your app.yml? (makes sure you hide password or any API keys)
I can not upload attachements so I pasted it here
## After making changes to this file, you MUST rebuild for any changes
## to take effect in your live Discourse instance:
## Make sure to obey YAML syntax! You can use this site to help check:
## http://www.yamllint.com/
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting by uncommenting the web.ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
## Comment out the following lines if you wish to add Lets Encrypt for your Discourse install
# - "templates/web.ssl.template.yml"
# - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
expose:
- "80:80" # fwd host port 80 to container port 80 (http)
- "443:443" # fwd host port 443 to container port 443 (https) (ssl ready)
# If you want Discourse to share a port with another webserver like Apache or nginx,
# see https://meta.discourse.org/t/17247 for instructions.
# any extra arguments for Docker?
# docker_args:
params:
## On 1GB installs set to 128MB (to leave room for other processes)
## on a 4GB instance you may raise to 1GB
#db_shared_buffers: "256MB"
## Set higher on large instances it defaults to 10MB, for a 3GB install 40MB is a good default
## this improves sorting performance, but adds memory usage per-connection
#db_work_mem: "40MB"
#version: tests-passed
env:
LANG: en_US.UTF-8
DISCOURSE_DEFAULT_LOCALE: en
## TODO: How many concurrent web requests are supported?
## With 2GB we recommend 3-4 workers, with 1GB only 2
## If you have lots of memory, use one or two workers per logical CPU core
#UNICORN_WORKERS: 3
DISCOURSE_DEVELOPER_EMAILS: 'REMOVED'
DISCOURSE_HOSTNAME: 'discourse.thefabulous.co'
## TODO: Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
## NOTE: 'true' is the only valid value here, any other will be ignored
#DOCKER_USE_HOSTNAME: true
## TODO: The mailserver this Discourse instance will use
DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org # (mandatory)
DISCOURSE_SMTP_PORT: 587 # (optional)
DISCOURSE_SMTP_USER_NAME: REMOVED # (optional)
DISCOURSE_SMTP_PASSWORD: REMOVED # (optional, WARNING the char '#' in pw can cause problems!)
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## The Lets Encrypt email will allow you to register a FREE SSL certificate if you added the Lets Encrypt template, comment it out if you have set this up
# LETSENCRYPT_ACCOUNT_EMAIL: email@awesomedomain.com
## The CDN address for this Discourse instance (configured to pull)
#DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discourse
## http://discourse.thefabulous.co/admin/docker
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
## Remember, this is YAML syntax - you can only have one block with a name
run:
## If you want to configure password login for root, uncomment and change:
## Use only one of the following lines:
#- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
#- exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'RAW_PASSWORD')" root
Hmm, there is a JavaScript error related to Cloudflare on your site. Might want to fix that first ![]()
A Parser-blocking, cross-origin script, http://ajax.cloudflare.com/cdn-cgi/nexp/dok3v=088620b277/cloudflare.min.js, is invoked via document.write. This may be blocked by the browser if the device has poor network connectivity
Thanks ![]()
do you think it’s related ?
It worked ! thanks a lot ![]()
