Annunci AdSense non funzionanti correttamente
Hey Guys! Need your help.
Recently, I started a website www.seokhazanas.com and have monetized it with google Adsense but ads not working properly. The problem is that ads are not loaded sometimes. Because of this, I am having a lot of problems, can you help me fix this?
Anyone have a solution or facing the same issue?
Do you see any errors in your browser console? When you say ‘not loaded’ sometimes, do you mean you don’t see ads on your entire site, or only on specific pages?
Are you running the latest version of Discourse and the ads plugin? If not, you should upgrade first.
Thanks for the reply, Yes i’m using latest version. I’m using Ad Inserter Plugin
