After a failed attempt on adding a plugin, I reverted to my backup. Tried relaunching. But getting this error. Please give me some solution
A user, Ajay26, reports a bootstrap failure after reverting to a backup, with an error indicating a Yarn version mismatch: the discourse module requires pnpm but Yarn 1.22.22 is being used. The error occurs during the yarn install step. pfaffman and Heliosurge request more details, which Ajay26 provides: the system runs Docker 26.1.3 on Rocky Linux 8.10. The issue appears to stem from incompatible package manager versions, likely due to a recent change in the Discourse codebase requiring pnpm instead of yarn.
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-loc && yarn cache clean' failed with return #<Process::Status: pid 312 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_co.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ \"$version \"tests-passed\" ]; then\n  rm -rf app/assets/javascripts/node_modules\nfi", "su dise -c 'yarn config set network-timeout 60000 -g'", "su discourse -c 'yarn install --n-lockfile && yarn cache clean'"]}
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, ther be more than one.
8364a2746508ebbe07b1d54773e6e25d7b98f529021d6272d5cf92cda68e1d8c
It’s not clear from what you included.
What version of docker do you have? What OS are you running?
As the lower lines in your clip. You need to scroll up in the log. There is likely error(s) that will help to identify the cause.
As Jay mentioned additional details are helpful. Like are you running Stable or Tests-passed. OS version and server specs can be helpful
Sorry for the confusion. I’m new to it. We have self-hosted a site with the discourse codebase.
Error (if it helps):
I, [2025-02-10T05:18:31.699440 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
error discourse@: The engine "yarn" is incompatible with this module. Expected version "please-use-pnpm". Got "1.22.22"
warning discourse@: The engine "pnpm" appears to be invalid.
error Found incompatible module.
I, [2025-02-10T05:18:31.982174 #1]  INFO -- : yarn install v1.22.22
info No lockfile found.
Docker version: 26.1.3
OS:
NAME=“Rocky Linux”
VERSION=“8.10 (Green Obsidian)”
