לאחר התקנת Docker של Discourse, לא ניתן להגיע לדומיין באמצעות הדפדפן שלי
I am using Mail gun for my SMTP, Name Cheap for my DNS and Digital Ocean for my droplet. named domains to discourse.jakubbanners.com on all 3 websites and made sure spelling is correct when using Docker. Installation says nothing failed, however still can’t reach the website.
This site doesn’t exist.
host discourse.jakubbanners.com
Host discourse.jakubbanners.com not found: 3(NXDOMAIN)
Double check that you set an A entry on your DNS with the IP of the DigitalOcean droplet where Discourse runs.
Hey @kabooshki ! Welcome.
Did you do a standard install? Did you run discourse-setup? It would have checked that you domain name was set and pointed to your server when you started.
Nevermind, i fixed it. just used cloudfare and everything seemed to work fine. Thank you for the replies though.
