Installed v2.2.0.beta3 +73
After I performed a recent admin/upgrade my Admin dashboard won’t load, just sits there spinning and then loads this:
The rest of the site works just fine.
In addition, that specific link it mentions which it seems loads the data for the graphs
/admin/dashboard/general.json
takes awhile and then gives this:
{"updated_at":"2018-10-19T18:38:11.106Z","last_backup_taken_at":"2018-10-19T18:14:25.000Z","disk_space":null}
Well, there’s your problem… you have null disk space ![]()
I have plenty of space, nothing via df -h is out of space. Also everything works as it should except for the Admin graphs. I’ve done a few /admin/upgrade since with no problems. Backups continue to happen with no issues.
$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 2.0G 0 2.0G 0% /dev
tmpfs 395M 46M 350M 12% /run
/dev/xvda1 99G 17G 78G 18% /
tmpfs 2.0G 1.1M 2.0G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/xvdf 50G 20G 27G 43% /var/lib/docker
/dev/xvdg 50G 8.9G 38G 20% /var/docker/shared/standalone/backups/default
cgmfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs 395M 0 395M 0% /run/user/1000
none 50G 20G 27G 43% /var/lib/docker/aufs/mnt/ef1a013ecf1a173d19b2459a065f61eb1d24e597ef94afcefc87761b8dcceff1
I also just did a rebuild and it’s still doing this…
Ok so no one has any ideas here? =) My dashboard is effectively dead and I have rebuilt multiple times with no errors.
Looking into my browser console:
content.js:150 Error: Cannot set user agent for iframe with location different to this page
and
error in _ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:9861
Uncaught TypeError: e.indexOf is not a function
at we.fn.init.we.fn.load (_ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js:9861)
at window.jsonFeed (b9a6ce49-e39b-4ac1-b776-b740bd27ba7b.js:6)
at geolocation.onetrust.com/cookieconsentpub/v1/geo/countries/EU?callback=jQuery33109029024044289335_1540209825048&_=1540209825049:1
a number of Failed to load resource: net::ERR_BLOCKED_BY_CLIENT for google analytics, twitter, facebook, etc.
and a number of errors for /whos-online
MESSAGE BUS FAIL: callback /whos-online caused exception s.user.get is not a function
then these:
admin/dashboard/general.json?_=1540209825052:1 Failed to load resource: the server responded with a status of 502 (Bad Gateway)
general.json:1 Failed to load resource: the server responded with a status of 502 (Bad Gateway)
I see this thread:
https://meta.discourse.org/t/latest-update-breaks-admin-dashboard/30987
which suggests a bad upgrade or incompatible plugin… no plugins added / changed between the last time things worked and the /admin/upgrade - so potential bad upgrade? I didn’t receive any errors either when rebuilding or the upgrade, so unsure what to do at this point?
Does your site work in safe mode? If it does, then try to find the plugin(s) that’s causing your issues.
Generally these errors only indicate that you are using some tool that blocks trackers
This is unrelated, is an error of which @david is aware of and that will fix as soon as he has time to do it (it appears from the previous version of Discourse).
Each update may inadvertently break third-party plugins already installed. Do you have unofficial plugins installed? Try to uninstall them and do the rebuild only with the official ones.
Much more likely it could be that you have the same problem that happened here:
Same issue in safe mode with everything disabled.
All official, with the exception of Who's Online
And yes, looks to be the same…
