AI semantic search shows [missing %[count} value] message
When performing AI semantic search, the message [missing %[count} value] appears.
The English text was changed, which removed the count parameter. The problem is that the translations aren’t updated when such a change happens, but only once the translations are updated after that. I suggested a while ago that, in such cases, translations should be updated faster, and I also reported this case as another example: Can outdated translations be removed on updates? - #5 by Moin
Translations were updated, and while so far no one has added a new translation for Chinese, the text is no longer broken. You should see the English text without the missing value until someone translates this on Crowdin.
I believe the translation is good here now.
