I’m having a hard time getting the semantic AI search to give me any results so I wanted to check with everyone and see if you all have any ideas on what could be wrong.
If I take a simple example and search for “shopify”, you can see I get plenty of normal results, but no AI results. When I compare this to searching for “shopify” in Discourse Meta community, you can see I get many normal results and many AI results. I’ve tried more complex and specific questions, but I still end up with no results.
As for our setup, we are using gpt-4o-mini and that is correctly setup under LLMs. “AI embeddings semantic search enabled” is enabled. We are using “text-embedding-ada-002” for the embeddings.
On a first glance, one issue I’ve found with your site current config is that while you are using text-embedding-ada-002 you’ve filled the embeddings configs for prompts, which are not supported for that model. I removed the instructions you had set there and regenerated the embeddings on your site.
I’m also updating the tooltip on those settings to try to avoid this confusion going forward
@Falco this seems to be working much better, thank you! I had added the prompts under the embedding configuration in an attempt to improve it, but of course it had no effect.
@Falco maybe I spoke too soon. Whenever I search now, AI always has exactly 40 results found regardless of what I search for. Many of the results are also not that relevant (suggesting the about this category topic for example).
I would expect 0 search results and 0 AI results in that particular case. We support ES6/ECMAScript2015 JS (yes very old), but it’s not in any community post as of yet.
Creates a new post about it taking into account the forum description
Returns the most semantically similar topics to it
There is no threshold of distance where we cut off the search, as finding out a general threshold that covers all thousands of Discourse instances is non-trivial. This is discussed at Setting a similarity threshold for semantic search.
We are looking into releasing a new approach that will do a more standard LLM + RAG search and return a conversational response, where you can tweak the prompt to say “no results found”. This is coming in the next weeks, will ping you here when you can test it.
That would be great. That’s what I was attempting to do with adding the prompts into embeddings section. Since you can’t set a threshold now, is that why we’re always seeing about 40 results?
Today, the AI search works like a failover system when the standard search returns no results, acting like an overpowered synonyms dictionary. However, in your case, the search query doesn’t have any possible results in the entire forum, which isn’t the use case it was designed to address.
Stay tuned for the next version of the search; it will be closer to what you want.
Yes I would like to test this on our site. I tested it on your site and also saw the existing “Hiding 50 results found using AI” toggle when in full search. Does this toggle still use the previous HyDE search?
The new feature doesn’t use the toggle at all. It shows the conversational answer above the standard search experience, and is here in tandem with the existing keyword and semantic search.
Could this persona have a custom tool tied to it? I’m thinking this could be a way to source relevant documentation from our external knowledge base to show these in search results without interacting with the bot.
