AI-samenvatting formatteert links niet correct
In the discussion titled ‘AI Summarization doesn’t properly format links,’ Canapin reported that AI-generated summaries incorrectly format Discourse post links—using ([1][/t/-/277694]) instead of the correct Markdown ([1](/t/-/277694)). This issue was observed while summarizing a thread about Font Awesome versions used in Discourse’s Category Icons plugin. sam noted that this problem occurs with Claude 2 but not GPT-4, and mentioned that @Roman had previously flagged similar edge cases. The bug was resolved by Falco, who confirmed the fix was merged in discourse/discourse-ai#183.
I summarized this:
The result:
This discussion is about which version of Font Awesome the Category Icons plugin for Discourse uses.
TechnoFox ([1][/t/-/277694]) asked what version Category Icons uses, wondering if an upgrade is possible. Firepup650 ([2][/t/-/277694]) responded that Discourse overall uses FontAwesome 5, so upgrading Category Icons alone would require changes to other parts of Discourse.
TechnoFox ([3][/t/-/277694]) followed up by asking if there are any plans to update Discourse to newer FontAwesome versions, and what might be preventing that.
Finally, pfaffman ([4][/t/-/277694]) linked to a meta post indicating Discourse has introduced FontAwesome 5 and SVG icons.
The links aren’t properly formatted. It wrapped the link with square brackets instead of brackets.
([1][/t/-/277694]) should be ([1](/t/-/277694)) → (1)
Yes, Claude 2 takes much coaxing, does not happen with gpt 4
@Roman had looking at some of this edge cases on his list somewhere
Fixed today in FEATURE: Better link in Claude summaries by xfalcox · Pull Request #183 · discourse/discourse-ai · GitHub
