Riprova a ricostruire l'app
Hello When I try to rebuild system give an error like;
/pups/lib/pups/config.rb:106:in `block (2 levels) in run_commands': Invalid run command cd (SyntaxError)
from /pups/lib/pups/config.rb:100:in `each'
from /pups/lib/pups/config.rb:100:in `block in run_commands'
from /pups/lib/pups/config.rb:99:in `each'
from /pups/lib/pups/config.rb:99:in `run_commands'
from /pups/lib/pups/config.rb:78:in `run'
from /pups/lib/pups/cli.rb:31:in `run'
from /pups/bin/pups:8:in `<main>'
Can you share the full error log? It’d also be helpful to know the directory you’re running the command in, and the exact command you’re running.
Ciao,
ho lo stesso messaggio di errore esatto dopo aver aggiunto il plugin discourse-oauth2-basic.
Ecco il log dell’esecuzione di sudo ./discourse-doctor in /var/discourse e la mia configurazione dell’app. Ho dovuto accorciare il file di log, perché è troppo lungo (non posso ancora allegare file).
[details=“discourse-debug”]
DISCOURSE DOCTOR Fri Jan 31 17:01:31 CET 2020
OS: Linux mycompany.com 4.15.0-58-generic #64-Ubuntu SMP Tue Aug 6 11:12:41 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=discourse.mycompany.com
SMTP_ADDRESS=smtp.sparkpostmail.com
DEVELOPER_EMAILS=REDACTED
SMTP_PASSWORD=REDACTED
SMTP_PORT=587
SMTP_USER_NAME=REDACTED
LETSENCRYPT_ACCOUNT_EMAIL=REDACTED
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 19.03.5, build 633a0ea838
DOCKER PROCESSES (docker ps -a)
CONTAINER ID        IMAGE                                COMMAND                  CREATED             STATUS                      PORTS        NAMES
ad746c498f75        local_discourse/app                  "/sbin/boot"             25 minutes ago      Exited (5) 11 minutes ago        app
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
==================== REBUILD LOG ====================
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up to date.
I, [2020-01-31T16:01:50.217918 #1]  INFO -- : Loading --stdin
I, [2020-01-31T16:01:50.223775 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2020-01-31T16:01:50.269771 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2020-01-31T16:01:50.270087 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-01-31T16:01:50.280071 #1]  INFO -- :
I, [2020-01-31T16:01:50.280310 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-01-31T16:01:50.285346 #1]  INFO -- :
I, [2020-01-31T16:01:50.285592 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-01-31T16:01:50.290605 #1]  INFO -- :
I, [2020-01-31T16:01:50.290884 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-01-31T16:01:50.294816 #1]  INFO -- :
I, [2020-01-31T16:01:50.295085 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-01-31T16:01:50.298472 #1]  INFO -- :
I, [2020-01-31T16:01:50.298708 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/01/31 16:01:50 socat[26] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2020-01-31T16:01:50.306809 #1]  INFO -- :
I, [2020-01-31T16:01:50.307072 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-01-31T16:01:50.313478 #1]  INFO -- :
I, [2020-01-31T16:01:50.313747 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-01-31T16:01:50.321026 #1]  INFO -- :
I, [2020-01-31T16:01:50.321278 #1]  INFO -- : > mkdir -p /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-01-31T16:01:50.326119 #1]  INFO -- :
I, [2020-01-31T16:01:50.326556 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-01-31T16:01:50.331104 #1]  INFO -- :
I, [2020-01-31T16:01:50.339854 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-01-31T16:01:50.349002 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2020-01-31T16:01:50.358572 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-01-31T16:01:50.369234 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2020-01-31T16:01:50.369761 #1]  INFO -- : > chown -R root /var/lib/postgresql/10/main
I, [2020-01-31T16:01:51.215344 #1]  INFO -- :
I, [2020-01-31T16:01:51.215639 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/10/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-01-31T16:01:51.221022 #1]  INFO -- :
I, [2020-01-31T16:01:51.221173 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-01-31T16:01:51.243321 #1]  INFO -- :
I, [2020-01-31T16:01:51.243605 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-01-31T16:01:51.249889 #1]  INFO -- :
I, [2020-01-31T16:01:51.250178 #1]  INFO -- : > /root/upgrade_postgres
I, [2020-01-31T16:01:51.260213 #1]  INFO -- :
I, [2020-01-31T16:01:51.260515 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2020-01-31T16:01:51.266115 #1]  INFO -- :
I, [2020-01-31T16:01:51.266828 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/10/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.267705 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.268223 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.268617 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.268994 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.269477 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.269825 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-01-31T16:01:51.276502 #1]  INFO -- :
I, [2020-01-31T16:01:51.277104 #1]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.277607 #1]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.278077 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.278591 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.278953 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/10/main/postgresql.conf
I, [2020-01-31T16:01:51.279517 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/10/main/pg_hba.conf
I, [2020-01-31T16:01:51.279894 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/10/main/pg_hba.conf
I, [2020-01-31T16:01:51.280136 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main
I, [2020-01-31T16:01:51.284468 #1]  INFO -- : > sleep 5
2020-01-31 16:01:51.309 UTC [49] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2020-01-31 16:01:51.309 UTC [49] LOG:  listening on IPv6 address "::", port 5432
2020-01-31 16:01:51.311 UTC [49] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2020-01-31 16:01:51.485 UTC [52] LOG:  database system was shut down at 2020-01-31 15:54:58 UTC
2020-01-31 16:01:51.502 UTC [49] LOG:  database system is ready to accept connections
I, [2020-01-31T16:01:56.288480 #1]  INFO -- :
I, [2020-01-31T16:01:56.289056 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2020-01-31 16:01:56.372 UTC [62] postgres@postgres ERROR:  database "discourse" already exists
Done compressing locales/el-f4d89589e78c0c675002c87e120a158db25ed05aea05544f798ca7bfe21be5e4.js : 0.08 secs
13337155.396820288 Compressing: locales/ja-211d3cd5efb2cd5997a5831c13a5a97f35b5d8552027c32b20955336238b18f0.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ja-211d3cd5efb2cd5997a5831c13a5a97f35b5d8552027c32b20955336238b18f0.js > /var/www/discourse/public/assets/locales/ja-211d3cd5efb2cd5997a5831c13a5a97f35b5d8552027c32b20955336238b18f0.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ja-211d3cd5efb2cd5997a5831c13a5a97f35b5d8552027c32b20955336238b18f0.js --output=/var/www/discourse/public/assets/locales/ja-211d3cd5efb2cd5997a5831c13a5a97f35b5d8552027c32b20955336238b18f0.js.br
Done compressing locales/ja-211d3cd5efb2cd5997a5831c13a5a97f35b5d8552027c32b20955336238b18f0.js : 0.07 secs
13337155.466588276 Compressing: locales/sq-ff23388bd2ec7eb1c9c8ae5669cadc680b7dbcb5ee9455644a1a6eb5b4f7a5f6.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sq-ff23388bd2ec7eb1c9c8ae5669cadc680b7dbcb5ee9455644a1a6eb5b4f7a5f6.js > /var/www/discourse/public/assets/locales/sq-ff23388bd2ec7eb1c9c8ae5669cadc680b7dbcb5ee9455644a1a6eb5b4f7a5f6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sq-ff23388bd2ec7eb1c9c8ae5669cadc680b7dbcb5ee9455644a1a6eb5b4f7a5f6.js --output=/var/www/discourse/public/assets/locales/sq-ff23388bd2ec7eb1c9c8ae5669cadc680b7dbcb5ee9455644a1a6eb5b4f7a5f6.js.br
Done compressing locales/sq-ff23388bd2ec7eb1c9c8ae5669cadc680b7dbcb5ee9455644a1a6eb5b4f7a5f6.js : 0.07 secs
13337155.536557427 Compressing: locales/pt_BR-d66dc5dbae6965e4d4030002ef79ecafc0848331f25cb4c2ec4c1ba7d1793b42.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/pt_BR-d66dc5dbae6965e4d4030002ef79ecafc0848331f25cb4c2ec4c1ba7d1793b42.js > /var/www/discourse/public/assets/locales/pt_BR-d66dc5dbae6965e4d4030002ef79ecafc0848331f25cb4c2ec4c1ba7d1793b42.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/pt_BR-d66dc5dbae6965e4d4030002ef79ecafc0848331f25cb4c2ec4c1ba7d1793b42.js --output=/var/www/discourse/public/assets/locales/pt_BR-d66dc5dbae6965e4d4030002ef79ecafc0848331f25cb4c2ec4c1ba7d1793b42.js.br
Done compressing locales/pt_BR-d66dc5dbae6965e4d4030002ef79ecafc0848331f25cb4c2ec4c1ba7d1793b42.js : 0.06 secs
13337155.60035402 Compressing: locales/lt-65da0ef79ac2bb13fb0438d74475752a7c8ad1772c44758e36f940a3dff5c35a.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/lt-65da0ef79ac2bb13fb0438d74475752a7c8ad1772c44758e36f940a3dff5c35a.js > /var/www/discourse/public/assets/locales/lt-65da0ef79ac2bb13fb0438d74475752a7c8ad1772c44758e36f940a3dff5c35a.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/lt-65da0ef79ac2bb13fb0438d74475752a7c8ad1772c44758e36f940a3dff5c35a.js --output=/var/www/discourse/public/assets/locales/lt-65da0ef79ac2bb13fb0438d74475752a7c8ad1772c44758e36f940a3dff5c35a.js.br
Done compressing locales/lt-65da0ef79ac2bb13fb0438d74475752a7c8ad1772c44758e36f940a3dff5c35a.js : 0.06 secs
13337155.662396437 Compressing: locales/te-33b081ed414beb02bb06275e28813eb78351045f822cd79c93dfaa09a1c519d7.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/te-33b081ed414beb02bb06275e28813eb78351045f822cd79c93dfaa09a1c519d7.js > /var/www/discourse/public/assets/locales/te-33b081ed414beb02bb06275e28813eb78351045f822cd79c93dfaa09a1c519d7.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/te-33b081ed414beb02bb06275e28813eb78351045f822cd79c93dfaa09a1c519d7.js --output=/var/www/discourse/public/assets/locales/te-33b081ed414beb02bb06275e28813eb78351045f822cd79c93dfaa09a1c519d7.js.br
Done compressing locales/te-33b081ed414beb02bb06275e28813eb78351045f822cd79c93dfaa09a1c519d7.js : 0.08 secs
13337155.74669595 Compressing: locales/zh_TW-539001075e574cd5c818cf34a5fe36db0cbea66290cfda127703160e4912ecd8.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/zh_TW-539001075e574cd5c818cf34a5fe36db0cbea66290cfda127703160e4912ecd8.js > /var/www/discourse/public/assets/locales/zh_TW-539001075e574cd5c818cf34a5fe36db0cbea66290cfda127703160e4912ecd8.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/zh_TW-539001075e574cd5c818cf34a5fe36db0cbea66290cfda127703160e4912ecd8.js --output=/var/www/discourse/public/assets/locales/zh_TW-539001075e574cd5c818cf34a5fe36db0cbea66290cfda127703160e4912ecd8.js.br
Done compressing locales/zh_TW-539001075e574cd5c818cf34a5fe36db0cbea66290cfda127703160e4912ecd8.js : 0.07 secs
13337155.815083925 Compressing: locales/de-c88c3fc69c206cccd9a23cd7272516c320f214a7242da1c04bcfe2c722b9a994.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/de-c88c3fc69c206cccd9a23cd7272516c320f214a7242da1c04bcfe2c722b9a994.js > /var/www/discourse/public/assets/locales/de-c88c3fc69c206cccd9a23cd7272516c320f214a7242da1c04bcfe2c722b9a994.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/de-c88c3fc69c206cccd9a23cd7272516c320f214a7242da1c04bcfe2c722b9a994.js --output=/var/www/discourse/public/assets/locales/de-c88c3fc69c206cccd9a23cd7272516c320f214a7242da1c04bcfe2c722b9a994.js.br
Done compressing locales/de-c88c3fc69c206cccd9a23cd7272516c320f214a7242da1c04bcfe2c722b9a994.js : 0.08 secs
13337155.895103691 Compressing: locales/gl-bc3f18b203d70f250eb09b185fb9e55bb6fb334d9387f69174fbcd6bc09c8765.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/gl-bc3f18b203d70f250eb09b185fb9e55bb6fb334d9387f69174fbcd6bc09c8765.js > /var/www/discourse/public/assets/locales/gl-bc3f18b203d70f250eb09b185fb9e55bb6fb334d9387f69174fbcd6bc09c8765.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/gl-bc3f18b203d70f250eb09b185fb9e55bb6fb334d9387f69174fbcd6bc09c8765.js --output=/var/www/discourse/public/assets/locales/gl-bc3f18b203d70f250eb09b185fb9e55bb6fb334d9387f69174fbcd6bc09c8765.js.br
Done compressing locales/gl-bc3f18b203d70f250eb09b185fb9e55bb6fb334d9387f69174fbcd6bc09c8765.js : 0.07 secs
13337155.962858276 Compressing: locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js
uglifyjs '/var/www/discourse/public/assets/locales/_en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js' -m -c -o '/var/www/discourse/public/assets/locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js' --source-map "base='/var/www/discourse/public/assets/locales',root='/assets/locales',url='/assets/locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js > /var/www/discourse/public/assets/locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js --output=/var/www/discourse/public/assets/locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js.br
Done compressing locales/en_US-8b46408c1c9706569bb5929e37521e7dd439e0cd05cfbba7ba57f8ee8dea134e.js : 2.66 secs
13337158.621891947 Compressing: locales/vi-5dd2a9e2abd66ad60f20308cbf58b09d02ab13f714672c327517aa5c90be582d.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/vi-5dd2a9e2abd66ad60f20308cbf58b09d02ab13f714672c327517aa5c90be582d.js > /var/www/discourse/public/assets/locales/vi-5dd2a9e2abd66ad60f20308cbf58b09d02ab13f714672c327517aa5c90be582d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/vi-5dd2a9e2abd66ad60f20308cbf58b09d02ab13f714672c327517aa5c90be582d.js --output=/var/www/discourse/public/assets/locales/vi-5dd2a9e2abd66ad60f20308cbf58b09d02ab13f714672c327517aa5c90be582d.js.br
Done compressing locales/vi-5dd2a9e2abd66ad60f20308cbf58b09d02ab13f714672c327517aa5c90be582d.js : 0.08 secs
13337158.699444544 Compressing: locales/da-c5d258d9bebe9499782a37be510586cf8982ebc193388c4034b883eae33d6cee.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/da-c5d258d9bebe9499782a37be510586cf8982ebc193388c4034b883eae33d6cee.js > /var/www/discourse/public/assets/locales/da-c5d258d9bebe9499782a37be510586cf8982ebc193388c4034b883eae33d6cee.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/da-c5d258d9bebe9499782a37be510586cf8982ebc193388c4034b883eae33d6cee.js --output=/var/www/discourse/public/assets/locales/da-c5d258d9bebe9499782a37be510586cf8982ebc193388c4034b883eae33d6cee.js.br
Done compressing locales/da-c5d258d9bebe9499782a37be510586cf8982ebc193388c4034b883eae33d6cee.js : 0.07 secs
13337158.767154092 Compressing: locales/nb_NO-06473e06cc16f3972da03f1becb702687c4e29f41277dd3e62d2d8307a3808c1.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/nb_NO-06473e06cc16f3972da03f1becb702687c4e29f41277dd3e62d2d8307a3808c1.js > /var/www/discourse/public/assets/locales/nb_NO-06473e06cc16f3972da03f1becb702687c4e29f41277dd3e62d2d8307a3808c1.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/nb_NO-06473e06cc16f3972da03f1becb702687c4e29f41277dd3e62d2d8307a3808c1.js --output=/var/www/discourse/public/assets/locales/nb_NO-06473e06cc16f3972da03f1becb702687c4e29f41277dd3e62d2d8307a3808c1.js.br
Done compressing locales/nb_NO-06473e06cc16f3972da03f1becb702687c4e29f41277dd3e62d2d8307a3808c1.js : 0.08 secs
13337158.846029934 Compressing: locales/ca-994d578d65be3b213b4a1924780b84dd6718f9903d7f03c047812f79c0bc62ca.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ca-994d578d65be3b213b4a1924780b84dd6718f9903d7f03c047812f79c0bc62ca.js > /var/www/discourse/public/assets/locales/ca-994d578d65be3b213b4a1924780b84dd6718f9903d7f03c047812f79c0bc62ca.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ca-994d578d65be3b213b4a1924780b84dd6718f9903d7f03c047812f79c0bc62ca.js --output=/var/www/discourse/public/assets/locales/ca-994d578d65be3b213b4a1924780b84dd6718f9903d7f03c047812f79c0bc62ca.js.br
Done compressing locales/ca-994d578d65be3b213b4a1924780b84dd6718f9903d7f03c047812f79c0bc62ca.js : 0.08 secs
13337158.928194184 Compressing: locales/uk-275fae7021a1e4d3f0d1e517fc6fdfed79efecab29564c7e190d27545aab112c.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/uk-275fae7021a1e4d3f0d1e517fc6fdfed79efecab29564c7e190d27545aab112c.js > /var/www/discourse/public/assets/locales/uk-275fae7021a1e4d3f0d1e517fc6fdfed79efecab29564c7e190d27545aab112c.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/uk-275fae7021a1e4d3f0d1e517fc6fdfed79efecab29564c7e190d27545aab112c.js --output=/var/www/discourse/public/assets/locales/uk-275fae7021a1e4d3f0d1e517fc6fdfed79efecab29564c7e190d27545aab112c.js.br
Done compressing locales/uk-275fae7021a1e4d3f0d1e517fc6fdfed79efecab29564c7e190d27545aab112c.js : 0.08 secs
13337159.01125006 Compressing: locales/ur-f7517c4fc4474d82fe11b16dcd6e3e5645f2429db7ff30f1d9c740026a4c5e5e.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ur-f7517c4fc4474d82fe11b16dcd6e3e5645f2429db7ff30f1d9c740026a4c5e5e.js > /var/www/discourse/public/assets/locales/ur-f7517c4fc4474d82fe11b16dcd6e3e5645f2429db7ff30f1d9c740026a4c5e5e.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ur-f7517c4fc4474d82fe11b16dcd6e3e5645f2429db7ff30f1d9c740026a4c5e5e.js --output=/var/www/discourse/public/assets/locales/ur-f7517c4fc4474d82fe11b16dcd6e3e5645f2429db7ff30f1d9c740026a4c5e5e.js.br
Done compressing locales/ur-f7517c4fc4474d82fe11b16dcd6e3e5645f2429db7ff30f1d9c740026a4c5e5e.js : 0.08 secs
13337159.094609339 Compressing: locales/ko-71c94fde3726c42a440a9b4f474a2ddd95c003c6e74113f9b467ad12d2a1d443.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ko-71c94fde3726c42a440a9b4f474a2ddd95c003c6e74113f9b467ad12d2a1d443.js > /var/www/discourse/public/assets/locales/ko-71c94fde3726c42a440a9b4f474a2ddd95c003c6e74113f9b467ad12d2a1d443.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ko-71c94fde3726c42a440a9b4f474a2ddd95c003c6e74113f9b467ad12d2a1d443.js --output=/var/www/discourse/public/assets/locales/ko-71c94fde3726c42a440a9b4f474a2ddd95c003c6e74113f9b467ad12d2a1d443.js.br
Done compressing locales/ko-71c94fde3726c42a440a9b4f474a2ddd95c003c6e74113f9b467ad12d2a1d443.js : 0.07 secs
13337159.161324956 Compressing: locales/sv-1145b12af6e46bebc1c466eb61a2b7182f209e73866b8101a837f56663cf5328.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sv-1145b12af6e46bebc1c466eb61a2b7182f209e73866b8101a837f56663cf5328.js > /var/www/discourse/public/assets/locales/sv-1145b12af6e46bebc1c466eb61a2b7182f209e73866b8101a837f56663cf5328.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sv-1145b12af6e46bebc1c466eb61a2b7182f209e73866b8101a837f56663cf5328.js --output=/var/www/discourse/public/assets/locales/sv-1145b12af6e46bebc1c466eb61a2b7182f209e73866b8101a837f56663cf5328.js.br
Done compressing locales/sv-1145b12af6e46bebc1c466eb61a2b7182f209e73866b8101a837f56663cf5328.js : 0.07 secs
13337159.235566113 Compressing: locales/sr-e8fe350f552ce1e679c633f69dda1d0179bec0447c1967877235a6529a596ebc.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/sr-e8fe350f552ce1e679c633f69dda1d0179bec0447c1967877235a6529a596ebc.js > /var/www/discourse/public/assets/locales/sr-e8fe350f552ce1e679c633f69dda1d0179bec0447c1967877235a6529a596ebc.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/sr-e8fe350f552ce1e679c633f69dda1d0179bec0447c1967877235a6529a596ebc.js --output=/var/www/discourse/public/assets/locales/sr-e8fe350f552ce1e679c633f69dda1d0179bec0447c1967877235a6529a596ebc.js.br
Done compressing locales/sr-e8fe350f552ce1e679c633f69dda1d0179bec0447c1967877235a6529a596ebc.js : 0.07 secs
13337159.302517887 Compressing: locales/fi-aa6d50b9e347c670e2e49abaaf609867599f812fecb8bfc7fc81fc103093dc0d.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/fi-aa6d50b9e347c670e2e49abaaf609867599f812fecb8bfc7fc81fc103093dc0d.js > /var/www/discourse/public/assets/locales/fi-aa6d50b9e347c670e2e49abaaf609867599f812fecb8bfc7fc81fc103093dc0d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/fi-aa6d50b9e347c670e2e49abaaf609867599f812fecb8bfc7fc81fc103093dc0d.js --output=/var/www/discourse/public/assets/locales/fi-aa6d50b9e347c670e2e49abaaf609867599f812fecb8bfc7fc81fc103093dc0d.js.br
Done compressing locales/fi-aa6d50b9e347c670e2e49abaaf609867599f812fecb8bfc7fc81fc103093dc0d.js : 0.08 secs
13337159.382234149 Compressing: locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js
uglifyjs '/var/www/discourse/public/assets/locales/_en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js' -m -c -o '/var/www/discourse/public/assets/locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js' --source-map "base='/var/www/discourse/public/assets/locales',root='/assets/locales',url='/assets/locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js > /var/www/discourse/public/assets/locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js --output=/var/www/discourse/public/assets/locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js.br
Done compressing locales/en-12e1a2a11b99c5e96e0ced60ad8049aa481672a516ff2f7c6af6492cb13e5a7c.js : 2.64 secs
13337162.018992439 Compressing: locales/ru-d35da2fc187e6124c922ccba68a2c273571e5b1ffca1f00f4c0b2e6bbb908ab6.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/ru-d35da2fc187e6124c922ccba68a2c273571e5b1ffca1f00f4c0b2e6bbb908ab6.js > /var/www/discourse/public/assets/locales/ru-d35da2fc187e6124c922ccba68a2c273571e5b1ffca1f00f4c0b2e6bbb908ab6.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/locales/ru-d35da2fc187e6124c922ccba68a2c273571e5b1ffca1f00f4c0b2e6bbb908ab6.js --output=/var/www/discourse/public/assets/locales/ru-d35da2fc187e6124c922ccba68a2c273571e5b1ffca1f00f4c0b2e6bbb908ab6.js.br
Done compressing locales/ru-d35da2fc187e6124c922ccba68a2c273571e5b1ffca1f00f4c0b2e6bbb908ab6.js : 0.09 secs
13337162.108946508 Compressing: docker-manager-app-888922f3ec4fc42543c1916f533f3fecb9af503803eb6b8b59904a2310219d1d.js
gzip -f -c -9 /var/www/discourse/public/assets/docker-manager-app-888922f3ec4fc42543c1916f533f3fecb9af503803eb6b8b59904a2310219d1d.js > /var/www/discourse/public/assets/docker-manager-app-888922f3ec4fc42543c1916f533f3fecb9af503803eb6b8b59904a2310219d1d.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/docker-manager-app-888922f3ec4fc42543c1916f533f3fecb9af503803eb6b8b59904a2310219d1d.js --output=/var/www/discourse/public/assets/docker-manager-app-888922f3ec4fc42543c1916f533f3fecb9af503803eb6b8b59904a2310219d1d.js.br
Done compressing docker-manager-app-888922f3ec4fc42543c1916f533f3fecb9af503803eb6b8b59904a2310219d1d.js : 0.01 secs
13337162.121823492 Compressing: docker-manager-vendor-91af87077979e715f4d5034ea05c612f734c3aece05878051e901d07e84878ee.js
gzip -f -c -9 /var/www/discourse/public/assets/docker-manager-vendor-91af87077979e715f4d5034ea05c612f734c3aece05878051e901d07e84878ee.js > /var/www/discourse/public/assets/docker-manager-vendor-91af87077979e715f4d5034ea05c612f734c3aece05878051e901d07e84878ee.js.gz
brotli -f --quality=6 /var/www/discourse/public/assets/docker-manager-vendor-91af87077979e715f4d5034ea05c612f734c3aece05878051e901d07e84878ee.js --output=/var/www/discourse/public/assets/docker-manager-vendor-91af87077979e715f4d5034ea05c612f734c3aece05878051e901d07e84878ee.js.br
Done compressing docker-manager-vendor-91af87077979e715f4d5034ea05c612f734c3aece05878051e901d07e84878ee.js : 0.13 secs
13337162.24796794 Compressing: plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js
uglifyjs '/var/www/discourse/public/assets/plugins/_discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js' -m -c -o '/var/www/discourse/public/assets/plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js > /var/www/discourse/public/assets/plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js --output=/var/www/discourse/public/assets/plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js.br
Done compressing plugins/discourse-internet-explorer-optional-4e74f38f94fc65150f5dda4e2592759b7d76be8771664c95188cee38116177b6.js : 0.54 secs
13337162.788113296 Compressing: plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js
uglifyjs '/var/www/discourse/public/assets/plugins/_discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js' -m -c -o '/var/www/discourse/public/assets/plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js > /var/www/discourse/public/assets/plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js --output=/var/www/discourse/public/assets/plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js.br
Done compressing plugins/discourse-details-fcee5b28139d24dd3fc6abaa7f4eaa9653070dbfacec9210b49b6691ee7f1c79.js : 0.27 secs
13337163.060949989 Compressing: plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js
uglifyjs '/var/www/discourse/public/assets/plugins/_discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js' -m -c -o '/var/www/discourse/public/assets/plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js > /var/www/discourse/public/assets/plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js --output=/var/www/discourse/public/assets/plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js.br
Done compressing plugins/discourse-internet-explorer-94a59cc54d7dfa189c6c0b90fe30742d2f65258346dab716d04b90339e81cfe0.js : 0.19 secs
13337163.255766297 Compressing: plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js
uglifyjs '/var/www/discourse/public/assets/plugins/_discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js' -m -c -o '/var/www/discourse/public/assets/plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js > /var/www/discourse/public/assets/plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js --output=/var/www/discourse/public/assets/plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js.br
Done compressing plugins/discourse-local-dates-27ed212e0ffdfb79b131a223e01a2833b86f7f7ca883a5e746e72731726dcac9.js : 0.68 secs
13337163.93322016 Compressing: plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js
uglifyjs '/var/www/discourse/public/assets/plugins/_discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js' -m -c -o '/var/www/discourse/public/assets/plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js > /var/www/discourse/public/assets/plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js.gz
[details="Log di rebuild"]
```text
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js --output=/var/www/discourse/public/assets/plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js.br
Compressione completata per plugins/discourse-narrative-bot-34c7a69c26a852a4f0464fc33b2abbf56163d77f77138d699a839ba8f260296d.js : 0.21 secondi
13337164.139228836 Compressione in corso: plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js
uglifyjs '/var/www/discourse/public/assets/plugins/_discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js' -m -c -o '/var/www/discourse/public/assets/plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js > /var/www/discourse/public/assets/plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js --output=/var/www/discourse/public/assets/plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js.br
Compressione completata per plugins/discourse-presence-b04740cb84eb76f9371a2ea6621c31c09f3043d4fdd2af917186caf5ba3d5df9.js : 0.43 secondi
13337164.573428644 Compressione in corso: plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js
uglifyjs '/var/www/discourse/public/assets/plugins/_docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js' -m -c -o '/var/www/discourse/public/assets/plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js > /var/www/discourse/public/assets/plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js --output=/var/www/discourse/public/assets/plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js.br
Compressione completata per plugins/docker_manager-25504a87a4e36bcc8a621591ad8ca39652edee1eb267254e2d16758445970569.js : 0.19 secondi
13337164.759912476 Compressione in corso: plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js
uglifyjs '/var/www/discourse/public/assets/plugins/_lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js' -m -c -o '/var/www/discourse/public/assets/plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js > /var/www/discourse/public/assets/plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js --output=/var/www/discourse/public/assets/plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js.br
Compressione completata per plugins/lazy-yt-cc6987f1bc1a01aed5e746c9cbe75ba9f4b9c6354f47a08b9608525a21a5f5c4.js : 0.28 secondi
13337165.042433845 Compressione in corso: plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js
uglifyjs '/var/www/discourse/public/assets/plugins/_poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js' -m -c -o '/var/www/discourse/public/assets/plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js' --source-map "base='/var/www/discourse/public/assets/plugins',root='/assets/plugins',url='/assets/plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js > /var/www/discourse/public/assets/plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js --output=/var/www/discourse/public/assets/plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js.br
Compressione completata per plugins/poll-a58910b1e81b6f79d37896523780dcf9288b179cb5f4db459c025c592a9818cc.js : 1.0 secondi
13337166.03979304 Compressione in corso: application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js
uglifyjs '/var/www/discourse/public/assets/_application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js' -m -c -o '/var/www/discourse/public/assets/application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js' --source-map "base='/var/www/discourse/public/assets',root='/assets',url='/assets/application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js.map'"
gzip -f -c -9 /var/www/discourse/public/assets/application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js > /var/www/discourse/public/assets/application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js.gz
brotli -f --quality=11 /var/www/discourse/public/assets/application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js --output=/var/www/discourse/public/assets/application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js.br
Compressione completata per application-5455881b0fb1ec1d69653a97c64cb3afcedb9f3e3dae6d791325073f2632d4e1.js : 20.5 secondi
Compressione completata per tutti i file JS : 68.17 secondi
Avvio compilazione CSS: 2020-01-31 16:06:00 UTC
Compilazione css per default 2020-01-31 16:06:00 UTC
precompile target: desktop Dark
precompile target: mobile Dark
precompile target: desktop_rtl Dark
precompile target: mobile_rtl Dark
precompile target: desktop_theme Dark
precompile target: mobile_theme Dark
precompile target: admin Dark
precompile target: desktop Light
precompile target: mobile Light
precompile target: desktop_rtl Light
precompile target: mobile_rtl Light
precompile target: desktop_theme Light
precompile target: mobile_theme Light
precompile target: admin Light
Compilazione CSS completata: 2020-01-31 16:06:09 UTC
I, [2020-01-31T16:06:09.503442 #1]  INFO -- : Downloading MaxMindDB...
Compressione Javascript e generazione Source Maps
I, [2020-01-31T16:06:09.517943 #1]  INFO -- : File > /usr/local/bin/discourse  chmod: +x  chown:
I, [2020-01-31T16:06:09.531043 #1]  INFO -- : File > /usr/local/bin/rails  chmod: +x  chown:
I, [2020-01-31T16:06:09.541185 #1]  INFO -- : File > /usr/local/bin/rake  chmod: +x  chown:
I, [2020-01-31T16:06:09.551646 #1]  INFO -- : File > /usr/local/bin/rbtrace  chmod: +x  chown:
I, [2020-01-31T16:06:09.560928 #1]  INFO -- : File > /usr/local/bin/stackprof  chmod: +x  chown:
I, [2020-01-31T16:06:09.570680 #1]  INFO -- : File > /etc/update-motd.d/10-web  chmod: +x  chown:
I, [2020-01-31T16:06:09.576458 #1]  INFO -- : File > /etc/logrotate.d/rails  chmod:   chown:
I, [2020-01-31T16:06:09.582137 #1]  INFO -- : File > /etc/logrotate.d/nginx  chmod:   chown:
I, [2020-01-31T16:06:09.592134 #1]  INFO -- : File > /etc/runit/1.d/00-ensure-links  chmod: +x  chown:
I, [2020-01-31T16:06:09.603798 #1]  INFO -- : File > /root/.bash_profile  chmod: 644  chown:
I, [2020-01-31T16:06:09.604310 #1]  INFO -- : Sostituzione di (?-mix:server.+{) con limit_req_zone $binary_remote_addr zone=flood:10m rate=$reqs_per_secondr/s;
limit_req_zone $binary_remote_addr zone=bot:10m rate=$reqs_per_minuter/m;
limit_req_status 429;
limit_conn_zone $binary_remote_addr zone=connperip:10m;
limit_conn_status 429;
server {
 in /etc/nginx/conf.d/discourse.conf
I, [2020-01-31T16:06:09.604800 #1]  INFO -- : Sostituzione di (?-mix:location @discourse {) con location @discourse {
  limit_conn connperip $conn_per_ip;
  limit_req zone=flood burst=$burst_per_second nodelay;
  limit_req zone=bot burst=$burst_per_minute nodelay; in /etc/nginx/conf.d/discourse.conf
I, [2020-01-31T16:06:09.620034 #1]  INFO -- : File > /etc/runit/1.d/remove-old-socket  chmod: +x  chown:
I, [2020-01-31T16:06:09.630781 #1]  INFO -- : File > /etc/runit/3.d/remove-old-socket  chmod: +x  chown:
I, [2020-01-31T16:06:09.631131 #1]  INFO -- : Sostituzione di (?-mix:listen 80;) con listen unix:/shared/nginx.http.sock;
set_real_ip_from unix:;
I, [2020-01-31T16:06:09.631488 #1]  INFO -- : Sostituzione di (?-mix:listen 443 ssl http2;) con listen unix:/shared/nginx.https.sock ssl http2;
set_real_ip_from unix:; in /etc/nginx/conf.d/discourse.conf
I, [2020-01-31T16:06:09.631934 #1]  INFO -- : > echo "Inizio dei comandi personalizzati"
I, [2020-01-31T16:06:09.636854 #1]  INFO -- : Inizio dei comandi personalizzati
I, [2020-01-31T16:06:09.637267 #1]  INFO -- : Terminazione dei processi asincroni
I, [2020-01-31T16:06:09.637407 #1]  INFO -- : Invio di INT a HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 49
2020-01-31 16:06:09.637 UTC [49] LOG:  received fast shutdown request
I, [2020-01-31T16:06:09.637762 #1]  INFO -- : Invio di TERM a exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 166
166:signal-handler (1580486769) Received SIGTERM scheduling shutdown...
2020-01-31 16:06:09.640 UTC [49] LOG:  aborting any active transactions
2020-01-31 16:06:09.643 UTC [49] LOG:  worker process: logical replication launcher (PID 58) exited with exit code 1
2020-01-31 16:06:09.645 UTC [53] LOG:  shutting down
166:M 31 Jan 2020 16:06:09.697 # User requested shutdown...
166:M 31 Jan 2020 16:06:09.697 * Saving the final RDB snapshot before exiting.
166:M 31 Jan 2020 16:06:09.770 * DB saved on disk
166:M 31 Jan 2020 16:06:09.770 # Redis is now ready to exit, bye bye...
2020-01-31 16:06:09.809 UTC [49] LOG:  database system is shut down
f4806ebfd53ad597901f42cfea676306543a66e1b64a6db8fee135a8416283f8
** BOOTSTRAP FALLITO ** scorri verso l'alto e cerca messaggi di errore precedenti, potrebbero essercene piĂą di uno.
./discourse-doctor può aiutare a diagnosticare il problema.
==================== FINE LOG REBUILD ====================
Ricostruzione app fallita.
Verifica del nome del dominio . . .
Connessione a discourse.mycompany.com riuscita.
Dovresti probabilmente rimuovere eventuali plugin non standard e ricostruire.
Tentativo di riavvio del container esistente. . .
+ /usr/bin/docker start app
app
Container riavviato.
==================== PLUGIN ====================
      - git clone https://github.com/discourse/discourse-oauth2-basic.git
Nessun plugin non ufficiale rilevato.
Vedi https://github.com/discourse/discourse/blob/master/lib/plugin/metadata.rb per la lista ufficiale.
Versione Discourse su discourse.mycompany.com: NON TROVATA
Versione Discourse su localhost: NON TROVATA
==================== INFORMAZIONI MEMORIA ====================
OS: Linux
RAM (MB): 32940
              totale        usato        libero      condiviso  buff/cache   disponibile
Mem:          32168        4017       18645          52        9505       27888
Swap:             0           0           0
==================== CONTROLLO SPAZIO DISCO ====================
---------- Spazio Disco OS ----------
Filesystem      Dimensione  Usato Disponibile Uso% Montato su
/dev/sda3       944G  362G  544G  40% /
==================== INFORMAZIONI DISCO ====================
Disco /dev/sda: 960 GiB, 1030792151040 byte, 2013265920 settori
UnitĂ : settori di 1 * 512 = 512 byte
Dimensione settore (logico/fisico): 512 byte / 512 byte
Dimensione I/O (minimo/ottimale): 512 byte / 512 byte
Tipo etichetta disco: gpt
Identificatore disco: 7C397D76-5FDF-AD44-BA49-97EB4FA4D146
Dispositivo       Inizio       Fine    Settori  Dimensione Tipo
/dev/sda1     2048       6143       4096    2M Avvio BIOS
/dev/sda2     6144    2103295    2097152    1G Filesystem Linux
/dev/sda3  2103296 2013265886 2011162591  959G Filesystem Linux
==================== FINE INFORMAZIONI DISCO ====================
==================== TEST MAIL ====================
Per un test robusto, ottieni un indirizzo da http://www.mail-tester.com/
Test mail saltato.
==================== Fatto! ====================
L'output di questo programma potrebbe essere disponibile all'indirizzo http://discourse.mycompany.com/REDACTED.txt
Dovresti ispezionare attentamente quel file prima di condividere l'URL.
Puoi esaminare l'output di questo script con
LESS=-Ri less /tmp/discourse-debug.txt
MA PRIMA, assicurati di conoscere i primi tre comandi seguenti!!!
Comandi da conoscere quando si visualizza il file con il comando sopra (chiamato 'less'):
q              -- esci
/error<INVIO>  -- cerca la parola 'error'
n              -- cerca la prossima occorrenza
g              -- vai all'inizio del file
f              -- vai avanti di una pagina
b              -- vai indietro di una pagina
G              -- vai alla fine del file
[/details]
app.yml
## questo è il template del container Docker Discourse all-in-one, standalone
## Dopo aver apportato modifiche a questo file, DEVI ricostruire
## FAI MOLTA ATTENZIONE DURANTE LA MODIFICA!
## I FILE YAML SONO SUPER SUPER SENSIBILI A ERRORI DI SPAZI O ALLINEAMENTO!
## visita http://www.yamllint.com/ per convalidare questo file se necessario
templates:
  - "templates/web.socketed.template.yml"
## Decommenta queste due righe se desideri aggiungere Lets Encrypt (https)
#  - "templates/web.ssl.template.yml"
#  - "templates/web.letsencrypt.ssl.template.yml"
## quali porte TCP/IP dovrebbe esporre questo container?
## Se vuoi che Discourse condivida una porta con un altro webserver come Apache o nginx,
## vedi https://meta.discourse.org/t/17247 per i dettagli
#expose:
#  - "80:80"   # http
#  - "443:443" # https
params:
  ## Imposta db_shared_buffers al massimo al 25% della memoria totale.
  ## verrĂ  impostato automaticamente dal bootstrap in base alla RAM rilevata, oppure puoi sovrascriverlo
  db_shared_buffers: "4096MB"
  ## può migliorare le prestazioni di ordinamento, ma aumenta l'utilizzo della memoria per connessione
  #db_work_mem: "40MB"
  ## Quale revisione Git dovrebbe usare questo container? (predefinito: tests-passed)
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  ## Quante richieste web simultanee sono supportate? Dipende da memoria e core CPU.
  ## verrĂ  impostato automaticamente dal bootstrap in base alle CPU rilevate, oppure puoi sovrascriverlo
  UNICORN_WORKERS: 8
  ## TODO: Il nome di dominio a cui risponderĂ  questa istanza Discourse
  ## Obbligatorio. Discourse non funzionerĂ  con un indirizzo IP nudo.
  DISCOURSE_HOSTNAME: discourse.mycompany.com
  ## Decommenta se desideri che il container venga avviato con lo stesso
  ## hostname (opzione -h) specificato sopra (predefinito "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  ## TODO: Lista di email separate da virgole che saranno rese admin e developer
  ## al primo accesso esempio 'user1@example.com,user2@example.com'
  DISCOURSE_DEVELOPER_EMAILS: REDACTED
  ## TODO: Il server di posta SMTP utilizzato per validare nuovi account e inviare notifiche
  # INDIRIZZO SMTP, nome utente e password sono obbligatori
  # ATTENZIONE il carattere '#' nella password SMTP può causare problemi!
  DISCOURSE_SMTP_ADDRESS: smtp.sparkpostmail.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: REDACTED
  DISCOURSE_SMTP_PASSWORD: REDACTED
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (opzionale, predefinito true)
  ## Se hai aggiunto il template Lets Encrypt, decommenta qui sotto per ottenere un certificato SSL gratuito
  LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## L'indirizzo CDN http o https per questa istanza Discourse (configurato per pull)
  ## vedi https://meta.discourse.org/t/14857 per i dettagli
## Il container Docker è stateless; tutti i dati sono memorizzati in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## I plugin vanno qui
## vedi https://meta.discourse.org/t/19157 per i dettagli
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
## Eventuali comandi personalizzati da eseguire dopo la compilazione
run:
  - exec: echo "Inizio dei comandi personalizzati"
  ## Se desideri impostare l'indirizzo email 'Da' per il tuo primo accesso, decommenta e modifica:
  ## Dopo aver ricevuto la prima email di accesso, ricommenta la riga. Deve essere eseguita solo una volta.
  #- exec: rails r "SiteSetting.notification_email='discourse@mail.kyub.com'"
  - exec:
    cd: $home/plugins
    cmd:
  - exec: echo "Fine dei comandi personalizzati"
Quando rimuovo il plugin, si ricostruisce e funziona correttamente. Ho anche provato ad aggiungere un altro plugin a caso (discourse-bbcode). Questo ha causato lo stesso problema.
Qualsiasi indicazione su come eseguire il debug in modo piĂą approfondito? @ozgurkuru come hai risolto tu?"}
Ciao!
Il problema è che stai cercando di aggiungere il plugin nella posizione sbagliata.
Guardando la fine del tuo app.yml:
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
  - exec:
    cd: $home/plugins
    cmd:
Noterai che hai il plugin docker_manager predefinito installato alla riga 8, mentre hai aggiunto la tua sezione del plugin piĂą in basso, alla riga 19. Dovresti rimuovere queste righe (16-19):
 - exec:
    cd: $home/plugins
    cmd:
Quindi aggiungi - git clone https://github.com/discourse/discourse-oauth2-basic.git direttamente sotto la riga del docker manager, assicurandoti che l’indentazione corrisponda.
Grazie @jomaxro! Probabilmente era quello, proverò lunedì.
Funziona alla perfezione. Grazie ancora @jomaxro :slight_smile:
