"Allow badge to be used as a title" - not persisting
The issue concerns the Allow badge to be used as a title setting for Regular badges not persisting after updates or deployments. AstonJ reported that the setting resets despite being saved. sam found it strange, noting the seed file only sets defaults. rishabh confirmed the issue with both Regular and Leader badges, showing the setting persists after saving but resets during deployments. meiadeleite and mentalstring corroborated the problem, with the latter noting it occurs during Docker image bootstraps. vinothkannans confirmed the fix is now in a pull request 13190.
I’m pretty sure I mentioned this before (but can’t find the topic now - think Sam said he had fixed it) but the Allow badge to be used as a title option for Regular badges is not persisting - it seems to get reset whenever there is an update.
This is very strange… looking at the seed:
All we do is amend the default in the seed file.
@jomaxro can community reproduce this issue?
I wasn’t able to reproduce it right away but since the problem seems to happen after updates, I’ll have a look at again later this week after a couple of deploys :hammer_and_wrench:
Thanks for the report @AstonJ, I can reproduce this now for the Regular and Leader badges :bug:
  1. Un-check “Allow badge to be used as a title” and Save. You’ll see that the change persists just fine across hard refreshes:
  2. Deploy the site and it’ll reset at the beginning of the deploy (and I think once more at the end):
I’ve also noticed this issue on our forum — the Regular and Leader badges keep getting used as titles, and when I check the settings, this option is active, despite me having already de-activated it a few times. :frowning:
Can confirm that this is happening with us too, every time we bootstrap our forum docker image.
https://github.com/discourse/discourse/pull/13190
This is now fixed in the above PR.
This topic was automatically closed after 7 days. New replies are no longer allowed.
