Hi all,
I’m working on this plugin which adds a setting to allow showing read-restricted categories in the category list.
This is already working (you can check the code in the Github repo), but now, as a next step, I want to show a custom view when a user with no access clicks on a restricted category.
My intention is to add a message to that view explaining that the category is private and encourage the user to register and request access to the category.
The way I’m doing this is adding a new NoAccessToCategory exception that is thrown whenever a user tries to access the restricted category, and now I’m trying to rescue from this category and show a custom template.
This is what I’ve done so far:
- Declare the new exception:
# lib/discourse.rb
class NoAccessToCategory < StandardError; end
- Tweak
CategoryGuardianso it throwsNoAccessToCategoryinstead ofNotFound:
# lib/guardian/category_guardian.rb
def ensure_can_see!(obj)
raise Discourse::NoAccessToCategory.new("Can't see #{obj}") unless can_see?(obj)
- Rescue in
ApplicationController:
# app/controllers/application_controller.rb
rescue_from Discourse::NoAccessToCategory do
if (request.format && request.format.json?) || (request.xhr?)
# No idea what to do here
else
render_to_string status: 200, layout: 'no_ember', formats: [:html], template: '/exceptions/no_access_to_category'
- Build the view:
# app/views/exceptions/no_access_to_category.html.erb
<h1>No access to this category</h1>
<div>
You don't have access to this category
</div>
This is working when I browse directly to a restricted category url (i.e. no AJAX request), but it’s not working when the category is accessed by clicking through the Ember frontend.
I’m completely unfamiliar with Ember (I come from a Rails background), and I would be very grateful if someone could give me some pointers as to how should I implement this.
Once it’s done, I will of course release this and hopefully will be of some use for other users – I’ve seen this requested in a couple of threads: here and here.
