Why hasn’t anyone developed an open-source Android app?
Hmm. I had a look in Customization > Extras and found a couple of iOS ones and one that said it supported Android with open source “planned”. You may be better off making one your self or paying for somebody else to do so for you because I don’t believe there is one at the moment.
לייק 1
I think that was also discussed here a few years ago Discourse sites in Playstore
4 לייקים
They have. It was called the whitelisted app and worked across both iOS and Android.
The need for such an app has reduced significantly because Discourse is a PWA and there is now native support for notifications from PWAs in both iOS and Android.
And installing a PWA to home screen is trivial on both OSes.
7 לייקים
