Zijn er nadelen aan proxy via poort in plaats van unix domain socket?
mcdanlj is testing Discourse on AlmaLinux 9 with SELinux enabled and external nginx. Due to SELinux issues with Unix domain sockets, they are considering proxying to a network port instead. They have made it work by setting httpd_can_network_connect to 1, exposing port 8008, and updating the external nginx configuration.
Falco noted that as long as direct connections to port 8008 are blocked, this setup should not be a problem.
Stephen pointed out that there is a difference in latency between using a socket and a local loopback port, with sockets being around 3 times quicker. However, the actual difference in latency is very small (around 4-5 microseconds).
mcdanlj plans to add proxy_set_header "Connection" ""; to disable the default Connection: close header. They will write up more detailed documentation after thorough testing.
I’m testing deploying Discourse on top of the CentOS-derived AlmaLinux 9 with SELinux enabled and external nginx configured.
Because the Ubuntu-based container doesn’t know about SELinux, it keeps replacing the unix domain socket with a new file that is not security labeled every time I start the container, and nginx isn’t allowed to talk to it until I restorecon the file to give it a security context that nginx is allowed to access. Obviously that doesn’t work as a production solution.
I don’t really want to semanage permissive -a httpd_t because I’d like to actually take advantage of SELinux on the one service that’s actually open to the outside world. :smiling_face:
It works if I proxy to a network port instead of to a unix domain socket:
  • setsebool -P httpd_can_network_connect 1
  • do not use templates/web.socketed.template.yml
  • `expose: - “8008:80”
  • In the external nginx, proxy_pass http://127.0.0.1:8008
Are there any particular downsides to this? Ought I to change any parameters like connection limiting in this configuration?
I’ll write this up in more detail as documentation after more thorough testing, and if there are additional concerns I can include that in what I write up.
As long as you block people from connecting directly to port 8008 using your preferred method, no problem.
Thanks!
public (active)
  target: default
  services: dhcpv6-client http https ssh
  ports:
  protocols:
  forward: yes
  masquerade: yes
  forward-ports:
  source-ports:
  icmp-blocks:
  rich rules:
There is a difference in latency, a socket is about ~3x quicker than a local loopback port.
That said, we’re talking a difference of 4-5us here at best.
After looking into this more, I definitely want to add proxy_set_header "Connection" ""; to disable the default Connection: close header
