Any suggestions on best ways to flag a topic as incomplete?
The discussion revolves around flagging topics as incomplete or “work in progress” in a Discourse-based wiki. tobiaseigen proposed a feature similar to Wikipedia’s “stub” indicator to encourage contributions. mcwumbly suggested using categories or the Tagger plugin as alternatives. tobiaseigen and others have been using a draft tag to track incomplete topics, but a more intuitive feature is desired. sam proposed a trivial plugin that applies a “stub” tag automatically to short topics.
We are using our discourse also as a wiki for collaboratively sharing information. I would like to be able to publicly flag a topic as incomplete - a work in progress - so everyone can see the topics that need attention and contribute to them. Something akin to the wikipedia “stub”.
I wonder if others have already solved this problem or if there is a plugin to handle this use case. Otherwise the long handed route is to add a prefix to titles or a keyword in the body of the message that can be searched. Anyone have better ideas?
Sounds like your current approach is pretty good. You could also try using categories to your advantage or employing the Tagger plugin.
Might as well close the loop here @tobiaseigen what ended up happening here?
This is actually a good idea, perhaps for special cases,for a small number of sites that use a more “strict” form . We can of course manually through editing to place any text, highlight it in any special way. Or try to implement this idea with an insert. We can manually insert a link on a previously created topic, where we will describe all of it. Lots of implementation.
Nothing happened, as far as I know. I’d still like to have the ability to indicate which topics are wiki “stubs” that are a work in progress and shouldn’t be relied on yet/need work.
We have been building up a knowledge base on our discourse, with a category and sub-categories that are all set to create wiki topics by default. We also have a kb admin tag that contains tags that can only be used if kb is also used. Among those is a draft tag that we use to keep an eye on topics that need work.
@angus and I have been talking about creating a knowledge base plugin. Maybe this could be included as a feature of that plugin?
What about tagging the work in progress with a stub tag? A trivial plugin could apply the tag automatically to short topics
