Is there something like an Archive or Trash Bin where when someone (OP, or mods) deletes their post, admins can see it?
It would be really useful in viewing history since my forum is money related.
Deleted topics are basically gone from all lists, even to moderators, and should be an extreme action.
If you just want to make a topic go away, I suggest using Close or Invisible instead.
The only other option we could think of is creating a Mod-only category and moving posts to it.
More hassle then hiding them, but Deleting isnât a workable choice.
The only drawback with hiding them is they donât âcollapseâ so topics could get long with them for Mods that can see them.
Itâs pretty common on vBulletin and phpBB forums to have a âGraveyardâ forum, all threads that are to be archived get moved there.
@codinghorror This would be a great feature! There should be an option in the admin panel that enables the âtrash canâ category (which only mods +) can see where all deleted posts can be seen.
As @haiku noted you can already do this right now, just create a category, edit permissions so it is visible only to staff.
But that means that I have to move the thread everytime, instead of just pressing delete.
Topics or posts? You can already see deleted posts inline.
We can probably add a method of viewing all currently deleted topics @Mittineague it just isnât requested much. @sam perhaps this is another querystring we need, to browse deleted topics in a category or all categories.
Topics.
It would be great to see. I just want a history of deleted topics just to resolve disputes if some money issue comes up.
The premise of your question is a little weird, because the OP (original poster) cannot delete their topic.
But mods can, and on request of the user, we will.
Hi Jeff,
Itâs not so much not being able to view them (Mods can) but that Delete has complications in the âleaving a paper trailâ way.
AFAIK from my albeit somewhat limited testing, When a post is Deleted it
Can not be found in Search
Removes any Notification Flags it might have had associated with it
We have a great team of Mods, but at times we like to cross-reference a new post with an older one.
eg. that âhavenât I seen this beforeâ feeling.
