Are existing any TeamSpeak integrations?
In a discussion titled “Are existing any TeamSpeak integrations?” under the Feature category, Daniel_Nevoigt asks whether there are existing integrations between Discourse and TeamSpeak 3 that can synchronize user groups and account status (e.g., registration, suspension, deletion) between the two platforms. He references a similar system used in Eve Online alliances and links to a TeamSpeak knowledge base article outlining how to integrate external user bases into TS3. Falco notes that TeamSpeak 3 lacks modern integration features like SSO and finds no existing solutions via web search. Daniel_Nevoigt acknowledges Discord’s popularity but emphasizes TeamSpeak’s continued relevance for certain user needs. Stephen confirms no existing Discourse plugin for TeamSpeak integration, calling it outdated, and suggests either developing a custom plugin or posting on the Marketplace for paid development. He also recommends Discord integrations as a more viable alternative. The thread highlights a niche need with no ready-made solution, pointing toward custom development as the only path forward.
Hello mates, I am wondering if there already existing any TeamSpeak integrations with discourse?
For example I am looking for something like that:
  • User registers on discourse and gets a standard discourse group, that group also assigns on ts3 server
  • when user gets other group in discourse, it also should change on ts3 server
  • when user deletes his account on discourse, or it gets suspended, it also should revoke server group for ts3
I know a similar system exists for a script called Alliance Auth. Possibly someone heard about anything related to our beloved discourse.
It’s been a while since I last used TeamSpeak 3 (all the kids are on Discord nowadays) but the system was pretty rough in terms of integrations. I don’t think they support any kind of outside SSO. And a quick web search also gave me no results.
Yes I know Discord is the thing right now, but still there are some features missing which let teamspeak still be the point for a huge user base. I know, like I said above, there are kinda php or also ajax frameworks existing to handle such things. I saw it myself when actively playing Eve Online in some big alliances, they used such stuff. I found the following article, and I think thats pretty much that what I am looking for:
https://support.teamspeakusa.com/index.php?/Knowledgebase/Article/View/5/12/how-can-i-integrate-large-existing-user-bases-eg-from-a-forumwebsitemmo-into-the-teamspeak-3-authentication-system
I was hoping some similar does exist for discourse already, or someone is developing it :frowning:
Nope, at this point TeamSpeak is a bit of a dinosaur. You can see from searching here on meta that yours is the only post on the topic.
There might be enough there for you to achieve this by writing your own plugin, alternatively if you aren’t comfortable with code but have a budget I would suggest posting on the Marketplace.
If neither of those things are an option for you then there are several Discord integration options already available :smiley:
