Zijn formulier-templates beschikbaar op self-hosted sites?
Superb. This is probably not available for self-hosted installations yet or in the beta versions only - correct?
Thanks
On a standard install, they’re available under the experimental form templates site setting.
It’s available on all sites using the tests-passed branch (the default one) as long as you’ve upgraded reasonably recently, and you should see it on stable when the next version is released in a few months time. :+1:
Thanks. Using up-to-date cloudron install and not seeing the options in the settings; happy to wait for the next relase! Cheers
So you’re not self-hosted, but Cloudron-hosted. :wink:
Well I feel very much self-hosted, but its not about emotions here :grin:
Cheers!
If you could switch to a standard install you’d be able to get support here.
