Are very long words not allowed in topic titles?
We had a user get an email-in topic rejected with the topic:
Adding DropMillisecondsHibernateInterceptor for MySQL 5.6+ compatibility
With the error message: Title is invalid; try to be a little more descriptive.
However, when he changed the title to:
Adding an interceptor to drop milliseconds for compatibility with MySQL 5.6 and above
The topic was accepted & processed.
  1. Does + really cause an email to be rejected? Must it be?
  2. If it must, can we at least get a more accurate error message?
1 лайк
I’m pretty sure that the issue is “DropMillisecondsHibernateInterceptor” (a very long word) and not the “+”.
Should disabling the title prettify site setting prevent long words from triggering an error?
It might, we detect long unbroken sequences of characters as griefing in titles.
Nevertheless, could the error message be changed to be more specific and better represent what users need to do to post their message? In this case, making it more descriptive would not help.
2 лайка
I think refactoring TextSentinel to make it show meaningful error messages for all kinds of ‘invalid’ titles and posts would be great.
2 лайка
Yes, absolutely. Right now the ambiguous error messages just confuse and frustrate users.
1 лайк
I just test by changing the default
max topic title length
from 255 to 25.
I must be missing something, this error message doesn’t seem at all ambiguous to me.
I think the problem is long words, not long titles.
Thanks, now I see.
I tried this for a Title
thisisonesuperexceptionallylongwordbeingusedasatitletoseeifitthrowsanerrorandifsowhatthaterrormessageis
And got this
Ironic, isn’t it?
3 лайка
It seems this does indeed involve text_sentinel.rb
It tests different things that a FAIL in any result in the same “invalid” message.
  def self.body_sentinel(text, opts={})
    entropy = SiteSetting.body_min_entropy
    if opts[:private_message]
      scale_entropy = SiteSetting.min_private_message_post_length.to_f / SiteSetting.min_post_length.to_f
      entropy = (entropy * scale_entropy).to_i
      entropy = (SiteSetting.min_private_message_post_length.to_f * ENTROPY_SCALE).to_i if entropy > SiteSetting.min_private_message_post_length
    else
      entropy = (SiteSetting.min_post_length.to_f * ENTROPY_SCALE).to_i if entropy > SiteSetting.min_post_length
    TextSentinel.new(text, min_entropy: entropy)
  def self.title_sentinel(text)
    entropy = if SiteSetting.min_topic_title_length > SiteSetting.title_min_entropy
    else
      (SiteSetting.min_topic_title_length.to_f * ENTROPY_SCALE).to_i
    TextSentinel.new(text, min_entropy: entropy, max_word_length: SiteSetting.title_max_word_length)
  # Entropy is a number of how many unique characters the string needs.
  # Non-ASCII characters are weighted heavier since they contain more "information"
  def entropy
    chars = @text.to_s.strip.split('')
    @entropy ||= chars.pack('M*'*chars.size).gsub("\n",'').split('=').uniq.size
  def valid?
    @text.present? &&
    seems_meaningful? &&
    seems_pronounceable? &&
    seems_unpretentious? &&
    seems_quiet?
  private
  def symbols_regex
    /[\ -\/\[-\`\:-\@\{-\~]/m
  def seems_meaningful?
    # Minimum entropy if entropy check required
    @opts[:min_entropy].blank? || (entropy >= @opts[:min_entropy])
  def seems_pronounceable?
    # At least some non-symbol characters
    # (We don't have a comprehensive list of symbols, but this will eliminate some noise)
    @text.gsub(symbols_regex, '').size > 0
  def seems_unpretentious?
    # Don't allow super long words if there is a word length maximum
    @opts[:max_word_length].blank? || @text.split(/\s|\/|-|\./).map(&:size).max <= @opts[:max_word_length]
  def seems_quiet?
    # We don't allow all upper case content in english
    not((@text =~ /[A-Z]+/) && !(@text =~ /[^[:ascii:]]/) && (@text == @text.upcase))
It would require code changes to have more specific error messages.
Maybe easier to just have the message point out the possible FAIL reasons and let users figure out which one was the problem?
Though I guess a better error message alone wouldn’t solve the OP problem if such was a necessity to use in the email.
I made a fix:
https://github.com/fenec/discourse/commit/849da848c14c5bc913609d45fcfcb0d90895fe99
Would be great to have some better wordings for errors.
That is not really the intent of this feature. We view it as anti-griefing, and telling griefers how to bypass filters is like Google telling spammers exactly what they didn’t like about their emails.
The only grief happening for us is on behalf of our legitimate users who can’t figure out how to successfully post topics. :frowning:
1 лайк
Have you tried tweaking your
Admin → Settings → Posting
settings?
1 лайк
Yes, for other issues. But AFAICT none of those settings relate to the issue raised in this bug.
What about this one?
1 лайк
