"Title is invalid; try to be a little more descriptive" - why?
Continuing the discussion from "Sorry, an error occurred" or 422 Unprocessable Entity: "Title is invalid; try to be a little more descriptive", as the software problem got fixed, but:
Why the following subject line:
 No such property: vcs for class: org.gradle.plugins.ide.idea.model.IdeaProject_Decorated
is deemed not descriptive? Is this because there was a closed, old thread with a similar subject? Some other reason?
It is difficult to revive old threads if necessary if we can’t reuse the subject line…
I have this site setting enabled in my discourse: allow duplicate topic titles
If the problem is on a discourse you manage, does enabling that help?
(not belittling any request for clearer error messages)
I filed another bug today and it turns out that it does not like too many dots. So instead of org.gradle.internal.graph.CachingDirectedGraphWalker I had to use CachingDirectedGraphWalker. Not so cool for Java programming tool forum :slight_smile:
Ha ha ha, sounds like you might need to create a topic for that here too!
Oh please, not!!! :slight_smile:
It is because a phrase with a lot of periods in between is considered a word, and a “too long” word. This has come up a few times @eviltrout and that regex should be changed to consider a period a “space” for the purposes of that check.
The goal is to block topics that have a title of aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa but the check needs to be a bit smarter about what it considers to be word breaks.
Yeah but on the other hand it would allow working around any (potential) filters L.I.K.E.T.H.I.S.
Workarounds are intentionally not, erm, worked around for these because it’s there to stop low-effort posting. Implementing a workaround implies effort. “You had to try, so we’ll just give it to you.”
This commit allows the title to work:
