Arrive at topic staat niet toe om te zoeken naar onderwerpen uit beperkte categorieën bij het aanmaken van een uitnodiging
In a UX-focused discussion, meglio reports that when creating an invite link and assigning users to a group with access to a restricted category (e.g., ‘Secret’), the ‘Arrive at topic’ dropdown does not display topics from that category — even though the group should have access. JammyDodger confirms the issue, noting that private topics don’t appear in the invite topic search regardless of group assignment, and provides a workaround: manually pasting the topic URL into the field. They also suggest an alternative method — using the :link: Share button on the private topic to generate invites, which prepopulates the ‘Arrive at topic’ field. meglio confirms the workaround works but recommends keeping the topic open for improvement. JammyDodger agrees the behavior isn’t technically broken but is unintuitive, suggesting it’s more of a UX issue than a bug, and notes the workaround’s convenience. The core issue remains: users expect to be able to search and select restricted topics in the dropdown when group permissions allow access, but currently cannot — requiring manual URL entry or indirect invite generation.
So, I’m creating a new invite link, and I’m adding to group secret that has access to category Secret. Now, I cannot choose a topic from Secret category in the Arrive at topic dropdown, even though logically I should be able to do so.
I’ve given this a test-run and it appears the ‘private’ topics don’t show up in the invite topic search whether you have the group set or not. It’s a little similar to this topic Category (Search Priority Ignore) globally affect searches, though in this case the category hasn’t been marked as ‘ignore’. However, the workaround is similar:
The repro:
  • Create Private group
  • Create Private Category, with permissions for See|Reply|Create set for Private group only
  • Create Private topic in Private category
  • Create admin invite:
    • Paste Private Topic link into ‘Arrive at topic’
    • Select ‘Private’ group for ‘Add to groups’
    • Save invite
  • Use invite with existing test user - user follows link and is added to the Private group, and lands on the correct topic
So I just have to put the URL of the topic in the dropdown list manually. Okay this worked, thanks.
Still, I suggest this topic remains open as it’s something that can be improved/fixed.
I think it would be more intuitive to have the topics come up in the search too. It may be more suited to Contribute > UX than Contribute > Bug as it perhaps can’t be considered ‘broken’, but I’ll let someone else make the call on that one. :slight_smile:
And, just as an added bonus workaround, you can also get the ‘Arrive at topic’ prepopulated by using the :link: Share button at the bottom of the private topic and accessing the invites from there. :+1:
