Is it possible to assign a topic for a group of users using the Assign plugin?
The discussion revolves around assigning a topic to a group of users using the Assign plugin. Initially, Roman_Rizzi clarifies that the plugin only allows assigning a topic to a single user. Joshua_Kogan and cwmke express interest in workarounds or future implementation of this feature.
Roman_Rizzi explains that this feature goes against the plugin’s purpose, as it makes it harder to determine responsibility. However, downey and Stephen share scenarios where assigning a topic to multiple users or a group would be beneficial.
Falco mentions that the team considered implementing this feature, but couldn’t reach an agreement on how it would work. Falco later confirms that it’s not on the roadmap for the plugin.
However, in a surprising turn of events, sam announces that this feature is now supported and implemented. The assign allowed on groups site setting controls the list of groups that can be assigned to, and when a topic is assigned to a group, it shows up in the individual assign list for all group members, with notifications when the assignment happens.
Hey @tkwong ![]()
No, you can only assign a topic to a single user. This user needs to be a member of an assign-allowed group.
Has anyone figured out ways to either assign multiple users, or use some other technique to workaround this limitation?
@Roman is adding this option likely in the future? It seams very useful for my situation. For example, being able to assign to DesignGroup or EngineeringTeam seems like it would be fairly common since those groups work on things together and only have 2-3 people in them.
I don’t think we’ll be adding this feature, sorry. I believe it goes against the purpose of the plugin because assigning a topic to a group makes it harder to tell who’s responsible.
Have you considered using tags instead?
Would the thinking be different if the question were phrased as:
Assign a topic/message to multiple users at the same time?
Very often we have a single request that needs to be handled independently by multiple people. (e.g., Persons X, Y, and Z need to do code review; team members A, B, C, and D all need to summarize their user interviews.)
Otherwise, we have to create parallel topics for the same request, to accomodate each assignee, which seems noisy.
We use assign in that way today, with the assignee being the task owner. Even if a task goes out to an entire team, each has a responsible party.
It would be really messy during a stand-up to ask for an update and have 15 people all try to chip in simultaneously.
We started considering an optional feature of being able to assign to groups.
No commitments yet, but we had some situations where it could be useful for largeish teams.
Any movement on this one? Would be hugely helpful for our team.
Thank you!
We discussed this again very recently, but couldn’t come up with an unanimous agreement about how it would work. It is not on the roadmap for the plugin.
This feature is now supported and implemented ![]()
The site setting assign allowed on groups controls the list of groups you can assign to. When a topic is assigned to a group it shows up in the individual assign list for all group members. They are notified when this assignment happens.
