Assign Posts as admin user to a moderator
I had no luck assigning a topic as an admin user to a user who is a moderator.
Did i again overlook some configuration options? :wink:
Hello,
Is this turned on? Enable the assign plugin
If so:
  1. Press assign at the bottom of a topic or private message.
  1. See writing in red.
Hello,
thank you for your fast response.
Yes the plugin assign is activated, and it works for assigning posts as moderator to another moderator.
Has any other staff been @mentioned? Maybe they have and you have to unassigned them first looking at your settings.
That’s the topic: Threema Work für andere Mitarbeiter an Schulen - Messenger: Threema Work - forum.bildungbw.de
I think no staff is mentioned and no one is assigned.
When I switch to a mod user and try to assign someone, I get a dropdown list showing the user:
When I try that using the admin user, this doesn’t appear:
Perhaps it’s a bug…
This has always worked for us, so I’m not sure what is wrong. All staff can be assigned. (staff = admins, moderators).
Thanks @Matze, I managed to track down the source of this issue. We were only searching ‘members of groups which you are also a member of’. So that works for ‘staff’ (like we have it here on meta), but it didn’t work for the separate ‘admins’ and ‘moderators’ groups.
Thank you for your fast and great support.
This topic was automatically closed after 28 hours. New replies are no longer allowed.
