Veja quem pode ser atribuído ao meu tópico
When I clic on ASSIGN I get this screen
I don’t understand the criteria to show the people picture.
There are more than these one on the staff/moderator group.
If I use the @ for the name, I get more people
some of them are even not staff member
I need to understand better how this works. ¿Can someone help?
The criteria for that list of suggested users is defined here
It basically boils down to the current user + up to 6 other users who don’t have assignments that exceed the number set in the max_assigned_topics setting.
Can you check the assign_allowed_on_groups site setting on your site? Members of groups added to that setting will show up if you use the search input.
7 curtidas
