Auto-complete with hashtag doesn't activate when hashtag is first character on a new line
When you start a hashtag to refer to another category or tag, if you start it as the first thing on a new line it does not bring up the autocomplete box. This is happening on my site, confirmed here on meta through screenshots below. This means that when I want to list categories one on each line, I have to first compose them on one line, then I hit enter.
They appropriately render, mind you:
Development
But if I don’t know the path for a subcategory or a tag, I have to guess or compose on a previous line to get the correct path.
Example here, with other characters first:
Newline, hashtag first:
I expect that occurs because the normal use of hash at the start of a line is for a heading …
… like this one
In markdown #text is a heading. Commonmark has a stricter specification of # text so it is possible that this is to maintain compatibility with older markdown.
To avoid the problem, which is not very common, I just put a space before the hash so autocomplete works.
If I mistakenly, out of habit, put the space before a heading then the heading will still work, e.g.:
hash prefixed by space
heading
Yeah this is a quirk we should sort out but it is a bit tricky
# this is a header
this is a header
So if we are to show autocomplete we need to only show it after the second key press so we don’t show it for # space, fixing this means we add another corner case.
