Tags verschijnen niet na het typen van #
The discussion addresses an issue where tags do not auto-populate after typing “#” at the beginning of a topic or reply. YAN reports this behavior, noting that tags appear when “#” is typed elsewhere but not at the start of a line. Stephen clarifies that this is intentional, as “#” at the start of a line is interpreted as a markdown heading. renato adds that a space after “#” is required for it to function as a heading, and references a feature request to improve tag autocomplete behavior in this context. JammyDodger directs users to the existing feature request on Meta Discourse for further input and attention.
Hi,
It’s pretty helpful that after typing “#”, all existing tags will pop up and users can easily pick tags from them, like this:
However, I found that if we type “#” in the beginning of a topic/reply, the existed tags won’t pop up, like this:
I wonder if this minor bug can be easily fixed? Much appreciate if anyone can give some ideas!
Hey Yan
A # at the start of a line is markdown syntax for a heading. This isn’t a bug, it’s by-design.
#this
renders as:
this
The # used for a heading is indeed the cause, but it can be improved: you need a space after the # for it to be a heading.
I’ll close this one off in favour of the open feature request (pr-welcome) if anyone would like to add their voice there and maybe get that some more attention. :slightly_smiling_face::crossed_fingers:
#tags won't autocomplete at start of line
