トピックを1分後に自動ロックしますか?
Hello,
So I’ve seen this on a Discourse Forum and I’m wondering how it’s done. In a particular category, topics are closed after a minute, how can you do this as the “Auto lock field” accepts hours only and not minutes?
Does anyone have any ideas on how to do this?
Oh wait I misread your question. Maybe they set it to zero hours. Not sure.
Why would you want this?
「いいね!」 1
Setting it to zero doesn’t work.
I found this post about how to close the topic immediately and a team member stated it should work but I’m not quite sure how
Bump, any ideas?
@codinghorror using this for a category where users will answer questions, and since I can’t deny permission to create and see but no replying, this is my only option.
It is a workaround, but you can put a number less than 1 in the “auto close topics” box. I just tried 0.001 and it closed the topic after a few seconds. Putting zero does not work.
「いいね!」 4
Thank you! That did the trick. Much appreciated.
