I am so much waiting this feature. Thank you for making it!
I have a problem with set up the trust level flairs which is maybe a bug. I don’t know is it relevant or not. Our forum is Hungarian language and the trust_levels also translated. I can upload and set up the flair but it is not appear on the users profile avatar only on the /g page. But I can set the admins, moderators and staff groups flair without any problem.
Thanks for trying it @Don. I can’t reproduce that problem. If you reload the page and visit the group settings again, do you see the uploaded image for the group? The error your screenshot shows suggests that it’s null. I don’t think it’s relevant that you’re using Hungarian and that you customized the trust levels text.
I notice in your video that the user has a shield beside their name, so they also belong to one of the staff groups. It could be a problem with one of those groups.
I see but i didn’t set flair to staff or any other named group. But if i try for example in other trust level group we have the same result. Every member has an empty avatar flair. I deleted the component but unfortunately the same. I will check the other components also. Maybe some conflict cause this.
