インポートしたフォーラムのトピックを、タイトル内のキーワードをターゲットにして自動的に再分類する機能?
Hi,
I’m importing an old and large forum about unicycling.
The old categories weren’t the best, and a lot of different stuff was mixed together.
So, I’m re-organizing categories.
At first, I was thinking to manually re-categorize the most recent few hundred of topics, and keep the old ones as they are.
The idea would be to aim at the future, not at the past. Doesn’t matter that much if old topics are badly categorized, the most important is that they are still available.
But I’m wondering if re-categorize topics automatically by targeting keywords could do, in fact, a good job.
Currently, the vast majority of our topics -more than half of the total!- are in a single category (:scream:).
I could target these keywords in the titles: “learn”, “learning”, “train”, “training”, “posture”, etc… And put all these topics in a category #riding-advice.
The same could go with “frame”, “wheel”, “tire”, “saddle”, etc… That would go in #unicycles-and-equipments.
I’ll target words wrapped by spaces and try to anticipate multiple words expressions and prevent a bit of “false positives”. Example: “wheelwalking” is a unicycle trick that should probably be found in #riding-advice, so if I target only “wheel” without thinking much, there will be false positives that could have been easily avoided (that said, I could move topics with “wheel” from A to B, and then move topics with “wheelwalking” from B to C…).
Did some people here do such a thing? Do you have suggestions or ideas to minimize the risk of “false positives”? Are there obvious (or not) things that I need to know before doing this?
About 70000 topics must be looked at.
「いいね!」 2
One bit of advise, do not view this as having to be done right the first time.
Your idea of seeking keywords is the same first approach I would take. Do not be afraid to throw out all of the work you did in your first attempt. If the result is not what you seek take what you learned by doing the first attempt and start over from scratch.
EDIT
In doing quick search for some free tools to do word analysis found this information page on Text Analysis. Nice read.
「いいね!」 3
I have previously approached similar projects by using unsupervised learning using K-means clustering. That would be a pretty cool experiment and maybe the algorithm even comes up with a better categorization :wink:
You can read about such an approach here https://towardsdatascience.com/applying-machine-learning-to-classify-an-unsupervised-text-document-e7bb6265f52
Just like @EricGT said: don’t be afraid to iterate, but close enough is close enough, and maybe have some TL3 users ready to re-categorize where necessary.
「いいね!」 7
That’s interesting!
I probably won’t have the time nor the skills to try this approach though (the forum has been down for more than a month, and I still have a lot of work to do!).
After a first try, manually choosing keywords seems to have fairly good results, though I didn’t re-categorized yet and just played with SQL queries.
select title from topics
where category_id = 10
and lower(title) not like '%saddle%'
and lower(title) not like '%crank%'
and lower(title) not like '%pedal%'
and lower(title) not like '%rim%'
and lower(title) not like '%carbon%'
and lower(title) not like '%spoke%'
and lower(title) not like '%wheel%'
and lower(title) not like '%frame%'
and lower(title) not like '%hub%'
and lower(title) not like '%tubeless%'
and lower(title) not like '%disk%'
and lower(title) not like '%hydraulic%'
and lower(title) not like '%duro%'
and lower(title) not like '%dominator%'
and lower(title) not like '%torker%'
and lower(title) not like '%nimbus%'
and lower(title) not like '%bearing%'
and lower(title) not like '%pad%'
and lower(title) not like '%repair%'
and lower(title) not like '%handlebar%'
and lower(title) not like '%kh%'
and lower(title) not like '%kris holm%'
and lower(title) not like '%coker%'
and lower(title) not like '%tube%'
and lower(title) not like '%build%'
and lower(title) not like '%29er%'
and lower(title) not like '%36er%'
and lower(title) not like '%backwards%'
and lower(title) not like '%riding%'
and lower(title) not like '%foot%'
and lower(title) not like '%train%'
and lower(title) not like '%training%'
and lower(title) not like '%learn%'
and lower(title) not like '%learning%'
and lower(title) not like '%dismount%'
and lower(title) not like '%habit%'
and lower(title) not like '%idle%'
and lower(title) not like '%idling%'
and lower(title) not like '%freemount%'
and lower(title) not like '%free mount%'
and lower(title) not like '%free mounting%'
This query returns 33000 topics of 52000 from the main category that could be re-categorized. The number seems realistic, but I still probably need to add more keywords.
The method seems reliable enough.
「いいね!」 2
What did you end up doing here?
If you have unique enough keywords in the topics (I assume you are iterating through all the topic replies and counting keywords in each post), it could be viable to automatically categorize a topic based on the presence of enough unique, specific keywords in that topic.
(This is primarily useful for migrations, though, since on a live forum you’d want the topic in the correct category at the outset.)
「いいね!」 2
I moved topics to other categories by checking keywords in their titles. It worked well enough to be better than the mess it was before.
「いいね!」 3
That’s a good point; a certain specific word consistently appearing in a lot of topic titles is strong evidence that a new category is needed. :thinking:
「いいね!」 4
クエリでこれを行いましたか?もしそうなら、クエリテンプレートは何でしたか?データベースの整合性を確保するために、クエリの実行後に他に何かアクティビティが必要でしたか?
「いいね!」 1
インポートスクリプトで実行されたように聞こえるため、タイトルからカテゴリを推測するように変更されたはずです。
インポートを実行していますか?どのソフトウェアからですか?すでにDiscourseに存在するものの場合は、Railsから実行できます。
「いいね!」 1
私が多くのDiscourse関連の仕事で彼を支援した限りでは、インポート後にRailsスクリプトを使用していたことを覚えています。彼はタイトル内のキーワードでトピックを選択し、公式に文書化されたコマンドを使用してそれらを移動しました。例えば、Administrative Bulk Operations のようなものです。
また、タグが付いたトピックを移動する際に、公式コマンドやrakeタスクでは一部のテーブルが完全に更新されず、関連する定期的なSidekiqジョブでも更新されなかったことを覚えています。
それがまだケースであるかどうかはわかりませんが、Bulk tagged topics, then moved topics into another category, but the category tag selector doesn't show tags - #3 by Canapin で注意すべき点かもしれません。
お役に立てば幸いです!
「いいね!」 1
