Move to existing topic should show category
As an admin (or moderator?) I want to be able to see the categories of posts when searching for a topic for which to move a post/reply, so I can more clearly identify the actual “correct” topic.
The current UI allows searching, but the results don’t show category, and with similar topic titles, this can quickly become confusing:
An easier way to look this up would be great :slight_smile:
@techapj can you add category here?
Longer term this should probably reuse search code…
PR sent:
