הדגשת תחביר Rust גרועה
Since A display error of the forum - meta - The Rust Programming Language Forum also happens on Meta, it looks like this is a problem in Discourse, not just our install.
#[derive(Parser)]
pub struct Arg {
  #[arg(short, long, default_values_t = [66,77])] // here, the brackets seems mismatched.
  pub(crate) arg1: Vec<u32>
Discourse uses highlightjs.org for syntax highlighting. I tried putting your snippet into their demo at Demo - highlight.js and it seems like the same issue is present:
So the best thing is probably to report the issue upstream to them (if there isn’t already a matching issue)
8 לייקים
https://github.com/highlightjs/highlight.js/issues/4032
5 לייקים
