徽章授予工作频率可配置吗?
The BadgeGrant job runs once per day, it would be great if we can up this a bit.
While I understand that for some large communities, this is a job best left during the off-season (e.g. 3am or so). I however, run a small community and I really don’t like the disconnect between actions and the badge being granted.
As an illustration, last run took half a second.
Jobs::BadgeGrant	22 hours ago	OK	504ms
It would be great if there was an option to run this more often (e.g. every hour, or even every minute).
1 个赞
I think you’d need a custom plugin to do that.
1 个赞
What badge exactly you are talking about?
Custom ones have multiple triggers to choose from (every post, every like, etc) and a lot of default ones are triggered immediately (first edit, first like).
6 个赞
Example is the stock higher love badge, that one runs daily as far as I know.
But if you really want, you could create a similar badge that was triggered on every post, so you’d not need to wait.
Yeah, but I think a product based solution is better than me and all other people doing a workaround :slight_smile:
1 个赞
