Migrazione bbPress e risposte private
Ciao,
abbiamo appena migrato da bbPress e ci siamo imbattuti in un piccolo problema. In sostanza, usavamo bbPress come forum di supporto e gli utenti utilizzavano le risposte private per pubblicare informazioni sensibili, come nome utente/password e/o la configurazione del file wp-config.php.
Ora abbiamo notato che questi argomenti sono ora visibili su Discourse. Abbiamo eseguito una ricerca sul database e sono stati restituiti un numero molto elevato di post che hanno utilizzato questa funzionalitĂ .
La mia domanda è: c’è qualcosa che potete consigliare per nascondere questi post agli utenti non amministratori/personale, o dobbiamo modificare il contenuto dei post o eliminarli?
Grazie
So the bbPress migrator did not properly migrate these as private messages? How many topics like this are there? You can use the admin wrench to manually convert topics to PMs as needed, but depending how many you have…
As far as I can tell all posts that were marked as private replies are still posts in the Discourse forum and haven’t been converted to PM’s. We’re still going through the database, but last time I spoke to my team there were 3600 posts. :frowning:
I think will run the migration again and see if the same thing happens again.
Private Replies is a third-party bbpress extension, which limits selected responses within threads as only being visible to staff and the OP.
Does the existing migrator handle them as PMs?
Hmm in that case you (meaning @Poshwaffle) may need to update the migrator to handle that third party extension…
Yep, as it is the migrator is working as intended by migrating all of the replies.
It wouldn’t (and in fact can’t) know about a flag being applied to certain topics in this way.
How are you planning to support Private Replies in Discourse?
Ah that makes sense and thanks for the responses.
We won’t be handling support via Discourse and is instead will be a community forum.
There are several ways to use Discourse to manage support requests, if you’re so-inclined. Group inboxes are also a great solution for this, and keep all your users engaged in one place.
You don’t support third party discourse extentions. :wink:
How to decide which bbpress extensions?
