Bessere Theme-Einstellungen im User-Frontend
Continuing the discussion from We need a "large fonts" and "small fonts" theme to ship with Discourse:
Our themes now support dark/light/{any-color-scheme} toggles as well as variable font sizes :tada:
But user interface for changing these settings is currently very basic:
We should have something closer to this (from GitBook):
I don’t have access to my usual image editor so here’s a cruder mockup than usual:
16 „Gefällt mir“
I think the <big> fix ruined it…
2 „Gefällt mir“
It shouldn’t have ruined anything except scaling for <big> and <small> tags, which should be avoided because they’re obsolete specifications that can be removed at any moment. <big> specifically is very bad because it will nest and scale infinitely if defined with ems.
I can probably change the <big> definition to a rem unit to prevent the exploit and allow at least some scaling based on the root font-size, but it still should be considered as relevant as the <blink> tag.
11 „Gefällt mir“
The plan has always been to add “user selectable theme components”
That means you can also flag “components” as selectable by end users. This would be done here:
Note, that screen shot is a “theme”, not default behaviour. My user selectable theme hamburger thingy ™ would have to be expanded to support this.
9 „Gefällt mir“
I suspected that might be a prerequisite for this feature.
Wouldn’t we want this front end widget (in particular the font sizer, which is a key accessibility feature) to be a default feature for every theme? So either (a) it should be bundled into core somehow, or (b) that theme component would be a default for all themes somehow, but the former sounds a lot easier to me.
9 „Gefällt mir“
I like this so much it hurts. Having a drop-down for each set of selectable theme components would make it a much cleaner presentation for the user. This is extreme granted, but instead of having a single dropdown with:
Standard Theme (Light w/ Normal Font)
Standard Theme (Light w/ Large Font)
Standard Theme (Dark w/ Normal Font)
Standard Theme (Dark w/ Large Font)
Standard Theme (Other Color Scheme w/ Normal Font)
Standard Theme (Other Color Scheme w/ Large Font)
Sam’s Simple Theme (Light w/ Normal Font)
Sam’s Simple Theme (Light w/ Large Font)
Sam’s Simple Theme (Dark w/ Normal Font)
Sam’s Simple Theme (Dark w/ Large Font)
Sam’s Simple Theme (Other Color Scheme w/ Normal Font)
Sam’s Simple Theme (Other Color Scheme w/ Large Font)
Material Design Theme (Light w/ Normal Font)
Material Design Theme (Light w/ Large Font)
Material Design Theme (Dark w/ Normal Font)
Material Design Theme (Dark w/ Large Font)
Material Design Theme (Other Color Scheme w/ Normal Font)
Material Design Theme (Other Color Scheme w/ Large Font)
Vincent Theme (Light w/ Normal Font)
Vincent Theme (Light w/ Large Font)
Vincent Theme (Dark w/ Normal Font)
Vincent Theme (Dark w/ Large Font)
Vincent Theme (Other Color Scheme w/ Normal Font)
Vincent Theme (Other Color Scheme w/ Large Font)
etc…
You’d be able to have something like:
Can’t wait for this feature!
15 „Gefällt mir“
We’re still planning user-selectable theme preferences for the future, but per-user font size selection is now part of core:
5 „Gefällt mir“
Ist dies bereits umgesetzt? Konkret benötige ich eine Benutzereinstellung für eine Theme-Komponente.
Wir haben es aus dem kurzfristigen Fahrplan entfernt, um die Dinge einfacher zu halten. Es könnte jedoch in Zukunft dennoch umgesetzt werden.
Je nach Ihrem Anwendungsfall können Sie möglicherweise Cookies oder localStorage verwenden, um gerätespezifische Daten zu speichern. Hier ist ein Beispiel dafür: https://github.com/discourse/discourse-defer/blob/master/common/head_tag.html
6 „Gefällt mir“
Super, danke! Ich wusste, dass es ein Beispiel dafür gibt, konnte es aber nicht finden. Ich brauche eine Texteingabe (kein Kontrollkästchen), ich werde es hoffentlich herausfinden.
2 „Gefällt mir“
