User anandm09 encountered a blank page after upgrading Discourse via the admin panel and SSH, with error messages indicating disk space issues and plugin conflicts. After cleaning up space using apt-get autoclean, apt-get autoremove, and ./launcher cleanup, and rebuilding the app, the site remained non-functional. Community members cpradio and DeanMarkTaylor suggested checking logs and disk space, with the latter confirming space exhaustion. Mittineague advised caution with CLI commands, while lostintime emphasized guiding newcomers. Removing the Google Adsense plugin temporarily restored functionality, but issues persisted across devices — working via IP but not domain. Error logs showed SSL/HTTPS warnings. codinghorror asked about localization or JS customizations, which were not enabled. sam pointed out that the Tagging plugin is now part of core and should be removed. After removing the plugin from app.yml, anandm09 confirmed the site fully recovered. The root cause was the outdated Tagging plugin, which should ideally trigger an upgrade warning or auto-remove. anandm09 declared the issue resolved.
Thanks! I am not very good at this and for the same reason I opted for installation services from discourse team itself. Waiting for Discourse team to response, with non-functional forum
While your advice in itself is good, I’m afraid it doesn’t really help @anandm09 to solve this problem, @Mittineague. Please bear in mind that this place can be a bit intimidating to newcomers …
I am new to this Docker stuff myself, so unfortunately I am unable to provide him with the steps to proceed with the upgrade but I assume he’d need to free up some space on his installation first, before backing up his postgres database as suggested in the screenshot.
Would it be safe to do
./launcher cleanup
at this stage?
Perhaps you could point him in the right direction with that?
Thanks for all the help but still there is some issue. When I upgraded after removing adsense plugin it worked on my device but I received many mails from our users that site is not working.
I check on multiple devices and realize that its working for few but not in others.
If you open IP address directly it works fine, but when website url is entered it does not show anything on devices with issue.
I have already tried deleting cache and temporary files from systems. It did not worked.
Its working at my end, will check on different devices in some time and confirm the status.
If tagging is included in core, the plugin should be removed automatically while upgrading or there should be some notification remove it before updating.
