Bootstrap mode was more than TL1 and more frequent activity summary emails. Those can quite easily be replicated by changing site settings. But I don’t know any setting for updating the user directory.
Bootstrap mode had been effectively disabled for a long time, the site setting was default: false for at least a year. And as a setting for new sites, that essentially means that we weren’t using the feature.
It has been replaced by the admin onboarding panel:
It’s a lighter touch to nudging new admins to do some key first steps: inviting users, sharing links, starting some topics. This banner displays for the first admin on the site, can be dismissed by the little X in the top right corner.
We should have announced this change, but since it’s a feature for new installations only, it felt a little unhelpful to “announce” it to existing admins. That said, meta is not only for existing admins, and it certainly is helpful to get feedback from the community.
So, thoughts, suggestions, ideas are welcome as always. Thanks for the question!
That statement really surprises me. Especially since, about a year and a half before you removed it, one of the product managers had noted that more documentation was needed.
That wouldn’t have made much sense if it had already been disabled back then.
Ok, you are right, I completely missed how this used to work.
Yes, you are right. It was enabled at the time that we removed the feature. (We had disabled it on some scenarios for our hosting.)
And on closer look, there are a few niceties in the bootstrap mode that we should keep, marking the first admin as a moderator and granting TL1 to the first group of new users stand out to me as desirable features.
That’s actually what I found least helpful. The “first day” limitations apply to users at TL1 just as much as they do to those at TL0; if you want users to be able to post more on their first day, you have to promote them to at least level 2.
I also liked that the user directory was updated more frequently. I understand why it is not possible with many users. But wouldn’t it be possible to do this until a certain number of users is reached? Especially in the beginning, it can be helpful to see your test users right there instead of having to wait for them. This makes it easier to configure what should be displayed there.
It depends on the view. The Daily view is updated every hour, the other views are updated every day. So when you join a site, if you go quickly to the directory and you land on the weekly view, you won’t see yourself there immediately.
This issue just came up on a new community I recently joined. Without bootstrap mode and little to read, engagement has been slow to pick up. One member started a topic because they were confused about receiving a PM email notification from staff and being unable to find the PM to reply. They are still TL0 and will be stuck there until there is enough to read so they can get up to TL1 and access their messages.
A corollary issue is that they are not able to just click a link in the email to access it directly and reply. They say they just got a blank page. I don’t know if this is related to another site setting change they’ve made or to trust level defaults.
Another funny side effect is that my own posts to meta to help educate that community about how all this works just got flagged! I presume that’s because I also am stuck at TL0 on that site. And hilarity ensues..
I wasn’t familiar with this, you are right. I made a PR to change this by giving higher default first-day limits for TL1 users and also by starting the clock at the user’s created_at date. Previously we were using the first post date, which is an odd choice, it can mean that a user could have “first-day” limits on their Nth day on the site, if they reply first only on the Nth day.
Penar, where are we at with this change? Are you going to revert the change so bootstrap mode exists again on newly created sites, or make more improvements to avoid the kind of engagement catch 22 I described above?
Personally I want to see bootstrap mode back. It takes care of the case where there are less than 30 posts. If it has to remain removed, there should be an adjustable threshold N that works like “the number of posts a tl0 user has to read to get tl1 is min(N, number_of_posts_in_forum)”.
