שינוי שובר עבור משתמשים בגרסאות יציבות (v3.2.1 ומטה) עם discourse_docker
This morning I accidentally run a launcher rebuild instead of launcher restart. Should have not been a big deal as we are running with a specific tag v3.2.1 instead of the test-passed and turns out that the build will fail due to a change pushed yesterday that raise the ruby version.
https://github.com/discourse/discourse_docker/commit/9f47034b0bdcb61fb99d5b051c3a041475bd8ae6
This will break stable version installations. So you are basically forced to install -beta versions or your installation will fail as v3.2.1 is still on the previous ruby version.
I, [2024-05-20T08:53:18.602308 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
google-protobuf-3.25.2-x86_64-linux requires ruby version < 3.3.dev, >= 2.7,
which is incompatible with the current version, 3.3.1
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4' failed with return #<Process::Status: pid 1276 exit 5>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle config --local deployment true'", "su discourse -c 'bundle config --local without \"development test\"'", "su discourse -c 'bundle install --retry 3 --jobs 4'"]}
bootstrap failed with exit code 5
I checked if there are tags for discourse_docker as it’s quite an important plugin and to my surprise there aren’t. Please be more careful when pushing changes to main.
5 לייקים
Thanks for reporting, we’ll get this sorted ASAP :eyes:
4 לייקים
We’ve reverted the discourse_docker change while we work on a plan for stable support.
6 לייקים
2 posts were split to a new topic: Error updating with broken events plugin
