Broken UI with CloudFlare after first installation with Docker
after installation using the documentation of Docker , Discourse is working fine but the UI is broken as the following Screenshot :
any Idea why this happened ??
By chance, are you behind Cloudflare? If you disable it, does it work?
I’m behind cloudflare , yes and another layer (HAProxy) , I disabled the cloudflare , and cleared the DNS and the cache , but still the same
Sorry an Update , Yes , it’s Working now , Thanks a lot . so What was the problem ??? the minify ?
Already solved here:
WOW Guys , You are the best
Thank youuu
In short, someone recently broke with Cloudflare, I’m not 100% sure what/how, and the permanent fix above shouldn’t be necessary, but it will get you operational for now until Cloudflare can analyze it.
