Problema con il pulsante Indietro del browser
Hi,
I am facing issue in browser back button. Some topics generally takes 2-3 back button clicks to reach to the previous page. This issue is happening only Chrome browser.
Can anyone help me with this issue?
If it is specific to a browser it is likely due to plugins or browser customizations. Try with a clean install of Chrome, or in incognito mode with all browser plugins disabled.
HI @codinghorror ,
I did all the things as you mentioned. Even i upgraded the discourse version to the latest. The issue is in posts having replies. Suppose a post having 3 replies, it takes 3 back button click to reach the original page .
Any idea why this is happening.
It is either your browser or a third party Discourse plugin causing the issue. If you have tried in a different browser, and disabled all third party Discourse plugins, that’s about it.
@codinghorror tried everything. Unfortunately the issue is still there. :disappointed:
If you can’t repro the problem here on Meta it means that the problem is only related to your site, so it can depend on 3 factors:
  • incorrect or unsupported or outdated installation
  • third-party plugins
  • themes and theme components
Have you tried using safe-mode disabling plugins and themes? Does the problem still occur?
Also, can you share a link to the site?
Here is the site.
