Azure でのサイト移行後のブラウザ Cookie の破損(?)
Hello,
I have migrated a Discourse platform from Vultur host to Azure, within a CentOS linux flavour. The migration went smoothly, using the built in database backup and restore process. We then delegated the DNS.
Some users (including myself at one point) are getting the sad face 500 error loading /latest.json. In all instances, clearing your cookies/sessions fixes the problem… but it appears to come back after half an hour or so.
I was also as an admin able to see during the error in my Settings section that the key-value pairs for the various settings labels were not parsed to a language locale e.g. “default locale” was displayed as something like “[en.default_locale]”.
I am not a Linux or Discourse guru so have no idea where to go with this issue. It may be things “settling down” after DNS migration, or there could be something more going on.
The problem so far has only been reported on Windows Chrome. I cannot reproduce on Edge or Chrome Android.
Looking in the /logs I see entries such as the following:
Job exception: PG::InvalidTextRepresentation: ERROR:  invalid input syntax for type inet:"106.70.36.109:6082" LINE 1: UPDATE "users" SET "ip_address" = '106.70.36.109:6082' WHERE...
Any advice would be appreciated.
Simon
「いいね!」 1
That is a well know Azure bug with some workarounds described here
「いいね!」 5
Chromium Edge or Legacy Edge?
「いいね!」 2
We came to this conclusion as well, and it was the case. The Appgw was sending its internal IPs instead of user IPs and presumably Nginx’ flood protection was kicking in. Updating Nginx configs solved the issue.
「いいね!」 2
