No, it isnât an IP address, and thatâs the problem. If youâve got a proxy thatâs including a port number in whatâs supposed to be an IP address, then the proxy is broken, and youâll want to get that fixed.
I havenât find the root cause yet. But I find a defected solution. By adding the following configuration in app.yml. I make the input of ip_address valid.
filename: /etc/nginx/conf.d/discourse.conf
to: $http_your_original_ip_header
global: true
The defected part is that the user ip_addresses are all 127.0.0.1 now. Itâs not perfect, but the 500 errors wonât throw finally.
The âforâ parameter is used to disclose information about the client
that initiated the request and subsequent proxies in a chain of
proxies. When proxies choose to use the âforâ parameter, its default
configuration SHOULD contain an obfuscated identifier as described in
Section 6.3. If the server receiving proxied requests requires some
address-based functionality, this parameter MAY instead contain an IP
address (and, potentially, a port number). A third option is the
âunknownâ identifier described in Section 6.2.
If your nginx setting is using $proxy_add_x_forwarded_for as the indicate of user ip. I think ip with port will be a valid input here. You may need to strip the port info out.
Q. Does Application Gateway support x-forwarded-for headers?
Yes, Application Gateway inserts x-forwarded-for, x-forwarded-proto, and x-forwarded-port headers into the request forwarded to the backend. The format for x-forwarded-for header is a comma-separated list of IP:Port. The valid values for x-forwarded-proto are http or https. X-forwarded-port specifies the port at which the request reached at the Application Gateway.
I will seek solution in rack or Azure Gateway.
Thanks @sam also.
Just to add to the conversation - this is standard practice in Azure Application Gateways, and itâs infuriating. They add the port to the forwarded-for header even though they also send it in the forwarded port header.
Two feedback/change requests on Microsoft which you can vote for;
Our âfixâ is also the same as the above step, weâre manually setting the forwarded-for header to a generic ip as this caused lots of issues with users being logged out or the site not working properly.
Just out of interest, we are using a httpd redirect within the network, does anyone know if it is possible to rewrite the header and remove the port? Failing that can it be done in nginx (I am unfamiliar with nginx)?
I would look at submitting a PR if we get this fixed but the comments above seem to suggest the devs would prefer this fixing upstream - is that the case?
Yup, for us it was immediately worth upgrading to v2 when it became available for production workloads. Azure Gateways do a lot of weird things, appending ports to forward-for IPâs are just one of the opinionated things that drove us nuts. Static VIPâs are wonderful.
Auto scaling gateway capacity is great to, saved our bacon once or twice already. And zone redundancy finally is very welcome.
Migrating took about twenty minutes and we have hundreds of listeners and some relatively complicated back pools, there is a power shell script to aid you, and itâs super simple.
Not sure if you use certificates on the gateway, but if you do v2 are super super fast - no more waiting 40 minutes to apply a cert, itâs seconds now.
Pricing is far more complicated (Microsoft give with one hand, they will always take with the other) but for us, so far, the bills have been the same or lower.
Lucky you. Because of the higher cost we needed to switch back to SKU V1 as soon as the V2 preview has ended.
Anyway, it seems that this issue/case has already been addressed upstream by a merged PR and should be included since rack 2.0. But according to this issue it is still missing in the current releases.
Temporarily I apply a patch during CI/CD to handle this issue. Itâs not that great but it will do the job until we see the fix in an upcoming rack-/discourse-release.
If anyone is interested, thatâs the part you need to change to get rid of the extra port in lib/auth/default_current_user_provider.rb:
if current_user && should_update_last_seen?
u = current_user
ip_port_split = request.ip.split(':')
ip_only = ip_port_split.first
Scheduler::Defer.later "Updating Last Seen" do
u.update_last_seen!
u.update_ip_address!(ip_only)
I donât know if it is a good idea to replace any occurrence of request.ip with this quickfix anywhere else in that file or others (email_controller.rb, 006-mini_profiler.rb, request_tracker.rb) but it works for us.
As said, applying it as a patch during your build-/CI-processes keeps the code-base clean and updatable.
