Built-in theme preview images missing (404) in discourse/discourse Docker image
I’m running Discourse using the experimental discourse/discourse:3.5.1 Docker image (via Docker Compose, not the launcher) and noticed that the built-in theme preview images are returning 404 errors in the admin themes page.
Environment:
  • Image: discourse/discourse:3.5.1
  • Deployment: Docker Compose on Dokploy
  • Database: PostgreSQL 17 with pgvector
  • Fresh installation (December 2024)
Issue: When accessing /admin/customize/themes, the browser console shows 404 errors for theme preview images:
https://forum.example.com/uploads/default/original/1X/d7dc093939924a0ce97287d65ec38bbcb2b23e00.png
https://forum.example.com/uploads/default/original/1X/f8a61b9a0bfac672daec9e401787812f8c5e28df.png
What I’ve tried:
  • Created proper upload directory structure: /shared/uploads/default/{original,optimized}/{1X,2X,3X}
  • Set correct permissions: discourse:www-data ownership
  • Ran rake uploads:regenerate_missing_optimized (completed successfully but didn’t generate these files)
  • Ran rake themes:update (no effect)
  • Verified symlink exists: /var/www/discourse/public/uploads/shared/uploads
Observations:
  • Theme previews work when clicked (themes function normally)
  • Only the thumbnail images in the theme selector are missing
  • The referenced PNG files don’t exist anywhere in the container
  • Database has upload records pointing to these non-existent files
Question: Is this expected behavior for the experimental image? Should these preview images be seeded during initialization, or is there a migration/task I’m missing?
The forum works perfectly otherwise - this is purely cosmetic. Just want to confirm if this is a known limitation of the experimental image or if I’ve missed a setup step.
You shouldn’t need to do that.
Do uploads work?
Did you run the rake assets:precompile? (or maybe those new images do that automatically–when I started trying to create such images, I think I had them do it on first boot.
