community.bookbrowse.com, my site is 3.6.0.beta1-dev with discourse calendar version 0.5, I should be able to see: BookBrowsers ask Graham Watson - BookBrowse Community Forum on my calendar: BookBrowse Community Forum but cannot.
@j.jaffeux is working on an upgrade of the calendar plugin, it should land some time this week.
Let’s see if this is still the case post upgrade.
Sounds good, I figured there was an upgrade in the works, thanks for the quick response!
Did an upgrade fix this? Post upgrade I am dealing with event posts not showing up on the calendar as of an upgrade today..
Update:
I fixed my issue by removing the calendar category setting I had that wasn’t really working anyway:
categoryId=4;postId=3;defaultView="week"
Yes removing this is indeed the way to go, I will deprecate this setting as it was incorrectly use multiple times.
This topic was automatically closed 10 days after the last reply. New replies are no longer allowed.
