¿Puede un plugin añadir un webhook?
I’m working on a plugin that communicates with an external web app. The web app is also informed of changes in Discourse through the use of webhooks.
Right now, installing the plugin is complicated, because it requires to also manually set up the webhooks. Is there a way my plugin could set up the webhooks itself?
I’m not much of a plugin author, but I’m pretty sure that you can call something like
hook = WebHook.new(payload_url: "https://sefsdf", secret: "lkjlkjlkj", active: true)
hook.save
Here are the other things in a webhook that you may or may not need to set.
 payload_url: nil,
 content_type: 1,
 last_delivery_status: 1,
 status: 1,
 secret: "",
 wildcard_web_hook: false,
 verify_certificate: true,
 active: false,
 created_at: nil,
 updated_at: nil>
Ah that would only create a web hook record in the database but doesn’t enqueue any jobs.
What kind of custom fields/webhook are you sending to your web app? You could subscribe to certain DiscourseEvents and add a custom Sidekiq job which calls an API on your web app.
Thanks @tgxworld. I’ve seen examples of how to use DiscourseEvents to emulate Discourse native webhooks here and here. I will try to do that if there’s no other choice.
But this seems complex. I would love to have a one-liner, like what @pfaffman proposed. When you use the UI or the API to create a webhook, doesn’t Discourse call an internal function I could also use from my plugin.rb file?
Is this a call to the kind of internal function I’ve just mentioned?
If you want to invoke a webhook when certain internal event happens, here it is the example. GitHub - erickguan/discourse-user-created-webhook · GitHub.
If you want to add a new type of webhook, here it is the example. GitHub - erickguan/discourse-webhooks-example · GitHub
Thanks a lot @fantasticfears, I will try this.
Esto es lo que finalmente hice:
Como necesito notificaciones estándar para la creación y eliminación de temas, me di cuenta de que Discourse ya las pone en cola como parte de la función estándar de webhooks. Por lo tanto, no es necesario hacerlo yo mismo.
Lo que queda por hacer, como sugirió @pfaffman, es agregar el webhook a la base de datos. Sin embargo, el código propuesto falla silenciosamente, probablemente debido a parámetros faltantes y/o incorrectos.
Aquí está mi código completo y funcional:
#customization:plugin.rb
# Agregamos nuestro webhook automáticamente, para que el administrador no tenga que hacerlo manualmente
after_initialize do
	# Eliminamos nuestro webhook instalado previamente (id reservado = 1000)
	WebHook.where(id: 1000).destroy_all
	# Creamos el webhook (id reservado = 1000)
	hook = WebHook.new(
		id: 1000,							# Nuestro id reservado
		payload_url: 'https://hfzeoihifzh/',
		content_type: 1,					# 1 = 'application/json'
		secret: "min12caracteres",
		active: true,
		web_hook_event_type_ids: [1]		# 1 = eventos de tema
	hook.save
