I have web space that is on a shared server that I do not have the option to get root access to. Is there a workaround for installing Discourse without having root level?
Thanks,
Leviticus
Thanks,
Leviticus
No that type of hosting isn’t supported.
However, getting a compatible VPS nowadays is very cheap at $5 in multiple places, like Digital Ocean and Vultr.
Thanks for your reply. I looked at Digital Ocean.
For $5 a month you get 25GB of space. If you have 50 Discourse members posting pictures and video links dozens per day…will 25 GB get eaten up fairly quick?
Does Discourse have a database trimming feature?
A video link, to let’s say YouTube is 43 bytes. 5GB can store 116279070 of those .
When disk space becomes an actual problem, instead of a theoretical one, you can use either Storage on DigitalOcean - Highly available Block Storage (at $0.10/month) or Spaces on DigitalOcean - Beautifully simple object storage at $5 for 250GB.
If you are expecting lots of uploads, I’d recommend going for the $10 2gb droplet and use spaces for uploads.
