Can I change or delete trust level?
I using Discourse business plan(hosting service).
I don’t use my trust level specifically.
Can I prevent it from being assigned when I register a new trust level, or can I delete the trust level itself?
Also, is it possible to change the name of the trust level to something like “Evangelist/Developer”?
I hope this post will helpful for you to hide trust levels.
Yes, you can change it on the admin side. Check the below URL on your Discourse website.
/admin/customize/site_texts?q=groups.default_names.trust_level_
Thank you your reply.
I solved my problem.
