Is het mogelijk om vertrouwensniveaus aan te passen?
Is it possible to customize automatic levels? type level 1 (confidence_level_1) instead of using the standard level 1, could I change this name to something of my choice? If yes, how to do it?
Are you talking about Trust Levels?
Yes that’s right
You can Customize text in Discourse
This way it doesn’t work, it only changes superficially, if I define an emblem for this category and choose it to use the name that appears when hovering the mouse over it is the original name even after changing!!
Can you provide a screenshot so we understand what you mean by emblem?
