האם אפשר להפוך את הפורום שלי לאפליקציה?
What tools do people typically use? I asked my friend to try to make it into an app. but it seems to be hard to handle the display between different phones. And lost the ability to drop down and instantly refresh the command.
I’d like to know what tools are available to facilitate easy use of our forums directly as an app!
There are ios android client apps, discouraehub. Are that you are looking for?
You might be interested in checking into
Discourse by default will give users an option to install an app if on a compatible browser ie chrome.
There is also a couple of projects on making an app for discourse
This repo will need updating to meet current standards and versions, but this essentially does the proper job:
Also at least Google allows you to deploy to Play Store as a PWA.
